I've got some brake questions. Don't worry, I've done my searches. In fact, I've probably spent way too much time at work today researching this.
My front brake on my '76 CB550K has developed a terrible squeal. I'm already planning on cleaning up the piston in the caliper and the seal. That's now what this post is about. There's enough info for that problem on these forums to... kill a horse. (say what?)
I'm here to discuss braided steel brake lines. My lower rubber line is cracked and dry-rotted--definitely in need of replacement. I figured why just replace it? Why not go braided?
There are two options I'm considering. I've outlined them both below.
Plan 1: Bypass the pressure sensor
I can get 1 stainless line to run from the master cylinder to the caliper bypassing the pressure sensor and the hard line. To do this, I'll have to get a banjo bolt with a built in sensor (like the one here:
https://helusa.worldispnetwork.com/secure/banjobolt/m10x125.htm). This is a simple, and seemingly clean setup. Fewer place to trap air bubbles, too.
I'll just need to buy 1 line, 2 banjos, 1 regular banjo bolt, and 1 sensor-banjo bolt.
Pan 2: Upgrade both rubber tubes
I can get 2 stainless lines to replace the two rubber lines. I'll still bypass the solid metal line near the caliper since it seems like a strange component to fit to braided lines. This way, however, I'll need to purchase 4 banjos and 1 or 2 banjo bolts.
I've already planned out the parts I will purchase from Z1 (
http://www.z1enterprises.com/catalog.aspx?pid=MFGO0)
So what have others done? What would you do? It sounds like plan 1 will cost less, but will require some electrical work. But Plan 2 is more stock.
Any thoughts?
Thanks for reading and giving any advice you may have.
