Author Topic: Battery  (Read 891 times)
Offline Pawsoff
Battery
« on: July 05, 2008, 09:27:13 PM »
I purchased a new battery today and 1A trickle charger. It was one of the "add your own acid" type of set ups. This was the first time I had done this, I filled it to the upper fill line.... Waited an hour and a half... tapped/rocked out air bubbles..... charged it for 7 hours (as per instructions)... now the fluid is above the upper fill line?
Should I, when I return to it tomarrow.. suck out the extra fluid down to the upper fill line? Lower fill line?
any help is appreciated
Pawsoff
1977 CB550F
On the road, slowly improving the bike :)
Offline Joel
Re: Battery
« Reply #1 on: July 05, 2008, 09:37:05 PM »
Did it build up any pressure inside?  Were the vents plugged or closed while it was charging?
Offline 333
  • Time for change
Re: Battery
« Reply #2 on: July 05, 2008, 10:36:03 PM »
Did you pull the vent plug off?
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline Pawsoff
Re: Battery
« Reply #3 on: July 06, 2008, 06:04:19 AM »
yup the vent plug was off and the tops were just sitting on, not snugged up
Pawsoff
1977 CB550F
Offline Pawsoff
Re: Battery
« Reply #4 on: July 06, 2008, 07:45:54 AM »
bump and suggestions
Pawsoff
1977 CB550F
Offline dpen
Re: Battery
« Reply #5 on: July 06, 2008, 07:59:19 AM »
Don't worry about it, any excess will come out the overflow tube when it's on the bike - just make sure the tube is not venting over part of the bike
  I may be telling you what you already know but:
no smoking of flames of any kind around battery whist charging (explosive gas)
  make sure caps are off while charging - be sure - put them to the side
Offline Bodi
Re: Battery
« Reply #6 on: July 06, 2008, 08:01:29 AM »
By some bizarre trick of chemistry the acid level always rises a bit after charging. Some of it's due to tiny bubbles attached to the plates, but even after vigorous shaking I always see a slightly higher level after charging.
