Author Topic: worth it?  (Read 1358 times)
Offline bert96
  • past ride
worth it?
« on: July 03, 2008, 12:28:43 PM »
 Does it worth 78$?
 big difference after this wiring is install?
http://www.yamiya750e.com/catalog/product_info.php?manufacturers_id=15&products_id=584
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
rhos1355
Re: worth it?
« Reply #1 on: July 03, 2008, 01:11:44 PM »
What is it?
Offline mystic_1
  • 1970 CB750K
Re: worth it?
« Reply #2 on: July 03, 2008, 01:17:28 PM »
It's a relay system for the headlight, with larger-gauge wiring.  Should help improve headlight brightness, but I have no experience with this.
mystic_1
- John Augustus Shedd
Offline SD750F
    • My Business Site
Re: worth it?
« Reply #3 on: July 03, 2008, 02:00:25 PM »
bert96,
Well I guess it depends on how comfortable you are with wiring. Because it does remove some of the wires between your High/Low beam switch and provide a more direct line between your battery/charger and horn. This will increase the current because of the reduced wire resistance. So if you look through the topics I pretty sure you will find discussion on how to make one of these yourself for nothing more than some wire, connectors, and a automotive relay that you can pick up at your local auto parts store. If you can't find the details, I know that there are several members who can help. Look first, then ask.  ;)
Scott
« Last Edit: July 04, 2008, 05:54:22 AM by SD750F »
Offline mystic_1
  • 1970 CB750K
Re: worth it?
« Reply #4 on: July 03, 2008, 03:21:13 PM »
In the "So, I want a loud horn" thread started by Hope, someone linked to the following horn which includes a relay:
http://www.bikerhiway.com/stebel-nautilus-compact-motorcycle-air-horn-black-p-74.html?utm_medium=frgl&utm_source=froogle&language=en
The installation instructions are pretty good, check it out:
http://www.bikerhiway.com/installinfo/Stebel/stebelhorn.pdf
Another useful link from that thread:
http://www.rattlebars.com/avalanche/relay_basics.html
IF you're skilled enough to install this, then you can probably put this together for way less than $78 (plus shipping) with parts from the local autoparts store, like SD750F said.
mystic_1
Offline SD750F
    • My Business Site
Re: worth it?
« Reply #5 on: July 03, 2008, 03:48:34 PM »
Little research...
Stebel Nautilus is rated 18 amps at 12 volts! That might be a drain on the power system.
If you go to Fiamm http://www.fiammamerica.com/default.asp there are a couple options.
The El Grande is rate 10 amps at 12 volts almost half the power draw of the Stebel.
Or the HK-9 standard buzzer is only 3 amps at 12 volts... And over 100 dB's!!!
Scott
Offline bert96
  • past ride
Re: worth it?
« Reply #6 on: July 03, 2008, 04:36:28 PM »
 I'll do a little more research...don't hesitate to post other links
 thanks
