Author Topic: 1977 CB550K highway rider?  (Read 1175 times)
keener
« on: July 08, 2008, 04:16:00 PM »
Well I have my bike out today for the first time and I am wondering if the 77 550K is a highway bike, I know it only has 5 gears but the revs seemed high for me on the high way doing 60 65 mph. they were around 5K rpm. is that normal? is there any way to lower my rpm at highway speed so I can do some distance driving without changing the gears?? the bike runs strong though otherwise. my throttle cable is very tough too and at idle climbs so I need to hold it cranked closed, anything I can do or just grease it up?? Thanks
Chris
Offline Shenanigans
  • Right turn?
Re: 1977 CB550K highway rider?
« Reply #1 on: July 08, 2008, 04:35:21 PM »
The 550 should have plenty of go for the highways. 5k in what gear, 5th? Make sure your clutch is not slipping and check to make sure you have stock sprocket sizes.
Offline gold72
« Reply #2 on: July 08, 2008, 04:42:01 PM »
I bomb on the highway on my cb500 all the time, my bike is happiest past 5k rpm
1972 cb500
Offline Gordon
  • 750K1, 550K2
« Reply #3 on: July 08, 2008, 04:50:54 PM »
You're just not used to a small, 4 cyl engine.  It needs to rev high, and it's supposed to.  As long as the engine is in decent shape you can run it all day long at 70mph (or more) with no problems.
Offline nilsey
« Reply #4 on: July 08, 2008, 05:25:35 PM »
actually i'm having teh same problem with the idle climbing, i ahve to hold the throttel down or it will go up to 2000-3000 rpm.
what;'s the usual diagnosis for this? anyone?
1976 CB550K: stock airbox, cb650 cam swap, 4x2 exhaust, dual disc brake conversion.
1974 BMW R90/6
Offline Gordon
  • 750K1, 550K2
« Reply #5 on: July 08, 2008, 05:30:46 PM »
1.  Throttle stop screw set too high, or throttle cable set too tight.
2.  Carbs out of synch.
3.  Carb vacuum leak.
There are other possible explanations, but in my experience those are the most common, and in that order.
keener
« Reply #6 on: July 08, 2008, 05:41:34 PM »
Any risk of over heating with the air cooled on the high way for 3 or 4 hrs?
Offline Gordon
  • 750K1, 550K2
« Reply #7 on: July 08, 2008, 05:56:26 PM »
Assuming your engine is in good shape and tune and you're not carrying more weight than the bike is meant for (and you're not riding through Death Valley in August, not much.
Admittedly, though, that's a lot of assumptions. ;)
Offline alltherightpills
« Reply #8 on: July 08, 2008, 06:03:32 PM »
It took me a while to get used to the high rpm's too.  Then I figured 5k is about halfway to redline, and at highway speeds my Civic is about halfway to redline, so it should all be okay. Not that there is any correlation between the two, just that halfway to redline seemed reasonable for cruising. :)
78 550K
77 550K (in pieces)
71 500K0 (in pieces)
martino1972
« Reply #9 on: July 08, 2008, 06:18:43 PM »
took me abit too to get used to the high rev,was even thinking of changing sprockets..
but now i learned to like the high rev,just give her hell,she'll love it....
