Tech Forums > SOHC/4 Bikes
CB400f - removing seat without seat lock key
<< < (2/3) > >>
Bodi:
This is a very easy lock to pick. It is a lock at least, unlike the key operated tank latches - but if you can't do it (there are lots of instructions on the web for picking pin cylinder locks and how to make the simple tools needed) any locksmith in the world will be able to open it in about 3 seconds. A locksmith can also make a key to fit or (possibly) adjust it to work with your key if you installed an aftermarket ignition lock.
RJBour9912:
I don't have keys for 400 at all. I have been using a flat blade Craftsman screwdriver to open the tank and the seat lock. It works great. I don't think the locks are damaged at all and they open just fine with the screwdriver.
Ley me know if this works for anyone else....you shouldn't need to force it, just turn the screwdriver as if it were the key.
cb650:
The latch is bolted to the seat and you should be able to get wrench or socket on it with the hinge pin out.
                  Terry
78_SaltLick:
yeah i was gonna ask if you tried putting your key in there, even if its not the right one, sometimes the will fit in there enough so when you turn it it will pop it open. Those locks are weak.
R. Hykawy:
If you have the ignition key it should work in your seat lock.When I bought my 400 it had no keys, i removed the ignition switch and took it to a lock smith. He cut me a key and it worked in the seat lock also.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
