Author Topic: rectifier and regulator  (Read 1361 times)
Offline bert96
  • past ride
« on: July 08, 2008, 12:41:58 PM »
What is the best thing to do,buy a rectifier AND a regulator separately or a regulator/rectifier
in one unit.Is there one more reliable than the other? is there a brand better?
Bert
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
Offline pablo78cb550
  • mmmph.
Re: rectifier and regulator
« Reply #1 on: July 08, 2008, 12:53:14 PM »
probably buy them separately,
that way if one breaks that's all you have to replace.
i was given these site.
http://www.oregonmotorcycleparts.com
Bikes in hand:
1977 Yamaha XS650
1978 Yamaha SR500 #119!
1978 Yamaha XS400
1978 Honda CB550K
1965 Ducati Monza 250
Sold off:
1992 Yamaha FZR600
1981 Yamaha Seca 550
Offline eurban
« Reply #2 on: July 08, 2008, 02:21:27 PM »
The stock rectifier is a solid state piece (no moving parts) so as long as yours is working, there isn't much to be gained / improved by replacing it.  The benefits of regulator replacement have been argued a good bit on this site.  I am quite happy with the solid state regulator that I purchased from Oregon Motorcycle Parts.  It has been in use for over 3 years and as he states on his site (at least for the 750s) it actually charges at idle with over 13 volts at the battery.  My stock reg never quite managed this.  I even have an electronic ignition, 3ohm coils and halogen headlight drawing additional power, although running lights are LED units. . . If you are looking to consoladate the parts into one piece for convenience or aesthetics then the combo units might be of interest.  If your rectifier is fried then a combo unit might be of interest.  The cost of separate pieces from OMP probably isn't much different than the cost of a good combo unit however, and the parts fit in the stock locations. . .Making sure that all the wiring is solid and connections are clean is probably one of the most import "upgrades" you can do on these old bikes.  Damaged wires and resistance from corrosion will suck up a lot of alternator output and can ruin your nice new electronics, so consider a wiring tuneup as part of the deal.  Pay attention to the fuse box in particular . . . . .
Offline bert96
  • past ride
« Reply #3 on: July 08, 2008, 02:45:52 PM »
 I've just change my fuse box,now running with ATC fuses,and i change my wiring harness
so i'm ok on this side.
Thanks for your  help!
Offline Pinhead
  • 1979 CB652-ST
« Reply #4 on: July 08, 2008, 03:12:25 PM »
Check the link in my sig!!
Doug
GM HEI Ignition Conversion
Quote from: TwoTired
:D
ev0lution7
« Reply #5 on: July 08, 2008, 06:34:23 PM »
here is my setup same thing it rocks!
