Well, I got the bike about 2 mo ago and it's been torn apart for the last month. Finally got it back on the road after a tune-up and light cafenation. It had a hesitation when tipping in from 1/4 throttle cruise and really didn't pull well over 4000. I figured because it had pods and 4 into 2 it would be lean, but with bypass screw 1 turn out, it would fire up cold without the choke and the plugs were black. I eventually ended up 2 turns out on bypass screws and 0 to 1/4 throttle got better, the rest didn't seem to change.
While it was down, I opened up the carbs and found them to be clean, so I set float height (it was only barley off) and put them back on. The jets were 40 and 105. I didn't check the rod height. Adjusted valves, filed and set points at .014, plugs at .030, static timed, chain tensioned etc...
Anyway, I synced my carbs, they were way off, using a home made manometer filled with ATF. Took it out for a test ride and I've made things worse. I'd bet carbs were adjusted before to cover up a jetting issue or something, and now that I've got things right on, all problems are very apparent.
So, it will take off from a stop fine, up to about 4000 rpm while giving it 1/4 throttle. After 4000, it starts missing/backfiring and popping in any gear at any speed. If I take off from a stop faster (over 1/4 throttle), above 2000 rpm it goes: pop, pop accelerate, pop, pop, pop, accelerate, etc...
Also, while idling, I can rev it up to about 1/4 to 3/8 throttle, but if I try to rap it with a quick 1/2 or more throttle, it just goes buaaagh and doesn't really rev at all.
From all I've read on the board, I probably need to re-jet. Any guidance on where to go from here and other adjustments that might need to be made?
Thanks,
Steve
