I have a '78 K. The front sprocket has one bolt, in the center. The chain seems LARGE to me, so I suspect it's the 630. I can see the sprocket is worn. From the discussion above, it sounds like I MAY be able to wiggle the chain and front sprocket out without breaking the chain. I'd appreciate comments on this, particularly if someone is certain this is impossible. My plan is to hit the nut in the center of the sprocket with an air wrench if possible, and a regular tool if not. While the chain is still on both sprockets. Anybody want to warn me against this plan?
I ended up removing the shift linkage cover in order to get the sprocket cover removed. I determined it is impossible to remove the sprocket cover without first removing the shift linkage cover. Why didn't they make the sprocket cover just a LITTLE smaller so this would not be necessary? Any thoughts?
And finally........As some of you know I am getting back into motorcycling after a 25-year hiatus. When I had a CB750 back in the seventies, I bought an impact driver. It was, and is, an ESSENTIAL tool for dealing with these screws on these motorcycles. As is a good selection of bits that fit properly and have square edges so they bite the screw head well and fit deeply. I am tempted to start a thread, just to alert/remind everyone of the importance of this tool. Is that silly? Does everyone already know this?
