Author Topic: Gear shift question  (Read 895 times)
Hondaboy
Gear shift question
« on: July 11, 2008, 06:22:11 PM »
The seal on my gear shifter is leaking oil, has anyone changed this seal and how difficult will it be? 1975 cb550
Re: Gear shift question
« Reply #1 on: July 11, 2008, 09:57:05 PM »
Clean up the area well. It is easier to remove the shiftershaft first, which means removing the clutch. Just check that the shaft isn't damaged around the seal contact spot.
« Reply #2 on: July 12, 2008, 05:28:09 AM »
Many people
Not very
part number 91205-hb2-772
Offline rhinoracer
« Reply #3 on: July 12, 2008, 05:36:29 AM »
I've done it but when assembling the motor which makes it pretty straight forward, so I can't comment on difficulty.
Like bwaller said, before sliding the new seal in check damage to the shaft that could nick the seal when going over it.
Baja native.
