Author Topic: CB750 f2 Camshaft on a CB750K7  (Read 3869 times)
Henning Jorgensen
« on: July 12, 2008, 08:21:21 am »
Hallo
Is it possible to use a camshaft from a CB750 f2 on my CB750 K7 engine, and will it affect annything. I want to keep it as original as possible, but I find it hard to find a K7 camshaft.
Regards Henning Jorgensen
Denmark
Offline strangedaze39
  • 1972 CB350F
Re: CB750 f2 Camshaft on a CB750K7
« Reply #1 on: July 12, 2008, 08:35:48 am »
Not sure, but welcome!
1972 Honda CB350F
Offline jtb
  • An unlikely
« Reply #2 on: July 12, 2008, 08:43:00 am »
Should be.
1977 CB750F
1985 V65 Sabre
Offline markjenn
  • CB750K1, CBX, RC30
    • Whizmo and Gizmo
« Reply #3 on: July 12, 2008, 10:36:35 am »
The F2 camshaft has a lot more lift than any of the K camshafts.  They're not remotely the same, although it may fit.
- Mark
Offline mazingerzeca
« Reply #4 on: July 12, 2008, 12:49:14 pm »
They have a different part number. I don't know if F2 camshaft's number coincides with any of the K series.
eldar
« Reply #5 on: July 12, 2008, 12:58:14 pm »
Well you should be able to fit it. The engines were about the same in basic mechanics. What you can do is reassemble everything with the F cam and put the head on without the gasket. Put putty on the pistons first. Then with the head on, turn the engine over. If the valves to not contact the putty, you should be safe then. You MAY want to put in stronger springs though. The k7 springs may not be strong enough.
« Reply #6 on: July 12, 2008, 12:59:53 pm »
It will fit no problem.
Henning Jorgensen
« Reply #7 on: August 17, 2008, 08:43:22 am »
The cam fits allright, but when the engine was in the bike and fired up. the pistons and valves were in contact. Engine out again and a another cam from Ebay was oredered, and now the engine is OK
« Reply #8 on: August 17, 2008, 08:55:11 am »
Hmmm...IIRC, the timing of the F2 cam is off by a couple of teeth, if the K sprocket is used with the F cam. Checking it with a degree wheel will usually show up this culprit.
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #9 on: August 17, 2008, 09:22:29 am »
Mark, you are saying properly timed, the cam should not cause valve/piston contact?
Asking because we are looking at waking up a K4 with your tricks, and the addition of an F2 cam.
No.
« Reply #10 on: August 17, 2008, 10:59:50 am »
I'd sure take a look at it. The F2 has more lift and duration, and it runs about 5 degrees later, when used with the F2 sprocket. I'm not familiar enough with the F2 top end to know how much geometry change is involved (rockers-valves-camlobe), but the degree wheel should always tell the story. That, and the clay on top of the piston.
If I were doing it: I'd advance the F2 cam in the early K engine, about 5 degrees from the F2 equivalent. This would make the starting points about the same, and the extra duration would really perk up the top end.
Offline eurban
« Reply #11 on: August 17, 2008, 11:04:38 am »
The stock valve springs on the F2 motors are stiffer than stock K ones. Something to keep in mind when using the F2 camshaft . . .
Offline Leanier
« Reply #12 on: September 29, 2010, 09:50:12 pm »
Just wondering if anyone has gotten any more specifics on putting the F2 cam in a k series engine.  I was thinking of doing this to mine to help add a little bit of power, along with exhaust jetting and pods.  Anyone tried it?  Were the results worth it?  And what all modifications were needed?
Thanks!
My motorcycle collection thus far:
'74 CB360
'73 CB750
'72 CB125s
'68 CA160
« Reply #13 on: September 30, 2010, 07:30:33 pm »
I just installed an F2 cam in a K8 engine. It went in fine, is cold-blooded, though. It's that late-duration thing. We'll be tearing it down in the near future for more cosmetic work and an improved F3 head, and I will probably advance the cam then to improve on the starting and cold-bloodedness.
« Reply #14 on: September 30, 2010, 07:41:59 pm »
