Author Topic: Honda factory part for Rearsets.  (Read 1152 times)
« on: July 12, 2008, 09:24:03 PM »
Found my bag of goodies..
 Have a 350 part thart should work on a 750  & others, for making controls. (if you can find them)
 Honda #24711-286-000
 Basically a shifter spline clamp part that has a hole for linkage abou an ich of shifter shaft centerline. Should work well, I think they were used on 69 CB350.. a bit rough looking but it does come chromed.
Offline mystic_1
  • 1970 CB750K
Re: Honda factory part for Rearsets.
« Reply #1 on: July 13, 2008, 12:34:45 AM »
I know the part you're referring to.  Some 350's had a complicated linkage system at the shift lever, with a really long shift lever that ran on it's own pivot.  My wife had a 73 CB350 that was set up like that.  We removed that setup and bolted up a 750 shift lever, it was a plug and play mod, so the other way around would work too.  I know for a fact that it fits the 750 splines because I've tried it.
mystic_1
- John Augustus Shedd
fuzzybutt
« Reply #2 on: July 13, 2008, 01:01:01 AM »
cx500's have those too i believe
