Author Topic: CB 750, when did they change..  (Read 920 times)
« on: July 12, 2008, 09:27:36 PM »
Rings to 3 pce?.. seems to me 72 had 1 pce?
Oil Pump.. found my NOS one today. Part # starts..15010-300
             in my early book it lists  for K) & earlier ..15100-300
Anyone know when they changed?
Re: CB 750, when did they change..
« Reply #1 on: July 12, 2008, 09:42:18 PM »
Late K2 sported 3-piece rings. I don't know the serial numbers, but it was almost K3 time.
« Reply #2 on: July 13, 2008, 08:50:40 PM »
according to my parts book ring part number changed for K2,
as for pump 15100-300 is complete pump whilst 15010-300 is the pump body only without the casting containing  relief valve and leak stopper
« Reply #3 on: July 13, 2008, 09:31:14 PM »
Honda's literature gets a little blurry sometimes, as far as parts vs. serial numbers...My K2 has a 90% K1 engine, but an early K2 serial number. Inside, it's K2-later clutch, K1 final drive, K1 rings (1-piece oilers, saw these clear into the 1972 K2 season on others, too), K1 cam & "holey" sprocket, K2 18T countersprocket, K2 carbs with 110 mains (K1 was 115 mains, K2 later was 105 mains in the 657B carbs). Spark advancer was K2, with shortened advance and lighter springs.
The 3-piece rings allowed looser bore straightness. They would still seal well that way, but not at real high RPM (>10,000). We would seek out the 1-piece ring and K1 pistons for that work, otherwise the rings fluttered a bit 'way up there, and burned oil as a result. The bores must be dead straight to have trouble-free 1-piece oil rings, though.
The oil pump: there was a change in the K1. I seem to remember it was the dowels and their related O-rings, but I don't have notes as to what, exactly, was different.
