Author Topic: Can you run resistor plugs?  (Read 841 times)
andmoon
« on: July 13, 2008, 04:36:06 PM »
I want to cancel the noise in my headphones.
Offline droopy
Re: Can you run resistor plugs?
« Reply #1 on: July 13, 2008, 04:53:59 PM »
I think so but you have to run nonresistor caps
2007 lifan 200cc sport ohc thumper
Offline 333
  • Time for change
« Reply #2 on: July 13, 2008, 05:42:08 PM »
It's not the plugs that are making the noise.  It's the coils.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
andmoon
« Reply #3 on: July 13, 2008, 06:47:07 PM »
Is there a way to quiet the coils?
I have 3 ohm aftermarket coils.
« Reply #4 on: July 13, 2008, 08:29:51 PM »
What ignitoin leads do you have and are you running resistor plug caps?  If so, what value?
Resistance is placed in the ignition lead system to soften the ignition pulse.  The removes the high frequency component of the spark signal to reduce radiation of electromagnetic signals from the ignition wires behaving as transmission antennas.
If you are powering your headphone driving appliance from the bike's electrical system, you may also have to filter the power input to that device, as your coils may be driving back EMF pulses into the bike's electrical system.
