Author Topic: tachometer needle swings wildly  (Read 1953 times)
Offline Six
  • Lucy - CB750F Cafe Racer
    • Motorcycle Diary
« on: September 02, 2005, 09:15:50 AM »
I bought and installed an NOS tach which looks great, but does not give me accurate readings.  It does not stay steady above 3K rpm's, instead it swings wildly between 4k and 11K when I gas it, and even during steady throttle riding, it swings about 2k up or down.
I've checked the cable, and it's not broken or kinked.  Do I just have a crappy tach, or is there something I can do to fix it?
Thanks!
Six - Mpls.
sradja
Re: tachometer needle swings wildly
« Reply #1 on: September 02, 2005, 09:23:07 AM »
Is the tach for your year and model? Sometimes on ebay people list tachs and speedos as one thing when they are not so.
Offline Six
    • Motorcycle Diary
« Reply #2 on: September 02, 2005, 09:41:23 AM »
I thought all SOHC CB750 tachs are the same!
Offline ericstew
« Reply #3 on: September 02, 2005, 10:24:34 AM »
The tachometers on old bikes use magnets to hold the needle in its reading position.
If they are de-magnetized,the needle just swings like yours.
It happens on many vintage bikes either on tacho or speedometers.
There is not much to do as the cost to replace the magnets is close to a new tacho...
cb 750 k2 950SS2 Japauto
cb 750 k6 1000VX Japauto
cb 750 F1 "cafe racer"
cb 750 k3 "cafe racer"
cb 750 k2
cb 750 k7 "cafe racer"
Offline Jonesy
  • Shop Rat
« Reply #4 on: September 02, 2005, 11:28:36 AM »
What condition is your tach cable in? If it's binding, it could be twisting itself up and giving the tach varying input.
Offline Tower
  • Only at conception could I have been called a
  • My personal time machine: 1973 CB750K3
« Reply #5 on: August 05, 2007, 04:28:34 PM »
I just snipped out my old broken High/Low switch and soldered in a new one  into the left-hand assembly on my 750K3.  The headlight still doesn't work, but now the tachometer swings wildly and erratically. wtf? Mere coincidence?
Took it for a spin with the wild tach.  It seemed to begin to settle down after about 30 miles, but not really.  Doesn't matter whether its at idle, WOT, with switches on/off or in either High/Low position.  Any ideas?
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #6 on: August 05, 2007, 07:07:28 PM »
The tach is 100% mechanical, I think it's a coincidence.  Check that your tach cable isn't kinked.  Maybe unscrew it from the tach and drip some oil down it.  Pull it out of the head and make sure there are no chewed up teeth on the spline gear.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline 333
  • Time for change
« Reply #7 on: August 05, 2007, 08:03:56 PM »
Lube the cable. Dri-Slide or some other dry lubricant works well.  If that doesn't work, replace the cable.  It's binding somehow, lube might fix it.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
