Author Topic: Rickman Honda cr750  (Read 2764 times)
Offline ericstew
Rickman Honda cr750
« on: September 02, 2005, 10:54:00 AM »
HI,
Does anyone know where I could buy a front master cylinder rebuilt kit (AP 2 disks)for my Rickman Honda Cr 750?Or just the part number
That's last thing to get my bike 100% restored...
Thanks
cb 750 k2 950SS2 Japauto
cb 750 k6 1000VX Japauto
cb 750 F1 "cafe racer"
cb 750 k3 "cafe racer"
cb 750 k2
cb 750 k7 "cafe racer"
Offline Geeto67
  • A grumpy
Re: Rickman Honda cr750
« Reply #1 on: September 02, 2005, 01:08:08 PM »
is it a stock honda master cylinder? Some of the rickmans came with airheart and lockeed brakes, I haven't the first clue where you would get a brake rebuild for one of those. When doing the dual disc conversion a lot of companies used a gold wing master cylinder also. are there any numbers on the master itself?
Maintenance Matters Most
Offline mcpuffett
« Reply #2 on: September 02, 2005, 03:25:59 PM »
hi, you could try david silver spares over here in the uk  ;)  mick.
Offline ericstew
« Reply #3 on: September 06, 2005, 12:56:46 PM »
It's a Ap lockeed master cylinder.I'm currently using a goldwing cylinder but I'd like to go back to the original part.
Thanks anyway
cb 750 k2
Offline Geeto67
  • A grumpy
« Reply #4 on: September 06, 2005, 01:08:12 PM »
Not sure if this helps but theHD FL and FX drum bikes came with lockheed m/cs, this place sells new reproductions.
http://www.legendmcs.com/Brakes/master-cylinders.html
Old brits stocks a lockheed caliper also for brit bikes, probably closer to what you are looking for:
http://www.oldbritts.com/ob_1420.htm
I used to have a lockhed master cylinder if I recall correctly the only pieces you will need to rebuild are o-rings which should be commonly available at an auto parts store. Without seeing your m/c I wouldn't be able to tell you more.
