Author Topic: Suggestions on replacing exhaust?  (Read 2957 times)
Offline Zeke
« on: September 02, 2005, 01:46:29 PM »
Hi:
Haven't written in a while, been too busy riding!!
Well, my #1 pipe on the original 4-4 finally cracked.  I had fixed a hole last year with JB Weld, Beer Can, and some bailing wire.  But Obviously, the steel inside is rotten.  Too bad, because the right side pipe is in good shape -- that why we only see the right side for sale....
Anyway, I have two options:
Mac 4-1 OR
Replacement Mufflers.
I like the 4-4 look, but I don't know how it will look with replacements.  I don't want it to look cheesy, so I'm asking you guys what are my options?
What companies offer original looking clamp on mufflers?  How do you like them?
Or, should I just go with the 4-1 MAC system.
Thanks,
Zeke
80 CB650c
Offline Egil
SV: Suggestions on replacing exhaust?
« Reply #1 on: September 02, 2005, 03:49:44 PM »
try csml heres the web address they have some in stock http://www.cmsnl.com
david silver spares in the uk have honda ones in stock heres the web address   http://www.davidsilverspares.co.uk/
merv
 If it cud help you Alget it from  bike54
Regards
Egil
73 de La2vpa.
Egil.
On The Edge.....That`s Where We Live Every Day.
My bike :
http://bike.no/member/photo.php?id=1605
Buffo
Re: Suggestions on replacing exhaust?
« Reply #2 on: September 02, 2005, 04:17:09 PM »
I sugjest tht you run a 4 into 1 with just the header and to start carrying a gun.  ;D
BTEAS
eldar
« Reply #3 on: September 02, 2005, 04:20:34 PM »
Well I stuck with 4-4 and got slip ons. The problem we face is that our bikes use a smaller diameter header than what is used today. I have to get adaptors made for my pipes. You can probably find something with a smaller opening though. I got slash-cut megaphones that are 24 inchs long or so. A bit shorter than stock but look very good. I will have to weld a bead around mine but was told If done right, I could polish the weld joint to shine good so it is not noticable.
bike54
« Reply #4 on: September 02, 2005, 06:40:42 PM »
hi
had a quick look at csml and david silver spares neither have any cb 650 exhausts in stock so if you want to keep 4 into 4 it looks like slip ons as for the slip ons being a biger diameter not a problem just get a peice of copper water pipe that slips over the headers that should take the diameter up to the slip ons if not put two peices on make a cut in the second peice and open it up a bit if its a bit big just file it down a bit before the final fit just smear jb weld over it you should get a good seal if you want to make sure fit a stainless steel exhaust clamp over the joint one of my exhausts has had a replacment muffler welded on it showes even with polishing its the diference in color between chrome and steel i finished up painting a half inch band over the joint in aluminium paint did the outher 3 to mach them up
merv   ;)
eldar
« Reply #5 on: September 02, 2005, 07:34:51 PM »
Tried the jb thing but it did not work. What happens is that without a solid mount the pipes flex and break the jb. Course I used jb quick but you have to mask areas to not make a mess then you have to pull the mask before the jb sets.
Offline Zeke
« Reply #6 on: September 03, 2005, 09:37:10 AM »
Guys:
Thanks for the suggestions so far.
I've looked at the slip-ons on loudfastugly (yeah, out of bidness) and a few look pretty good, but are definately longer than mine.
These are only about 17" long.
What mfrs are your favorite?
Thanks,
Zeke
Offline kghost
« Reply #7 on: September 03, 2005, 09:43:01 AM »
Try Mikes XS.
He's got a cool set of 15" Reverse Dunstalls. A set of 4 would look mighty cool.
Stranger in a strange land
Offline jotor
« Reply #8 on: September 03, 2005, 09:57:29 AM »
Zeke
Check JC Whitney (I know, I know...) They have different style slip-ons with adapters that go down to 1 5/8" or so.
I've made adapters out of sch40 steel pipe, cut to length then sliced long way with a hacksaw so they tighten up when you clamp 'em down.
I'd rather ride a Yamaha than eat worms.
Gallery.....http://www.sohc4.us/forums/index.php?topic=2254.0
Offline Zeke
« Reply #9 on: September 03, 2005, 10:06:43 AM »
Try Mikes XS.
Thanks, KG.  -- that site is nicely done.
I didn't see 15" but I did see 17" which is essentially what I have.
I have to say, that many of these sites with replacements really suck -- they don't have pics of half the stuff they sell.
I'll keep looking though.
I wonder what it would cost to get my header pipes re-chromed....
Zeke
Offline Zeke
« Reply #10 on: September 03, 2005, 10:10:53 AM »
Zeke
Howdy:
These 3 pc reducers are pretty cool and cheap -- looks like they are universal.
https://www.mikesxs.net/mikesxs-exhaust.php?category_id=5.1
scroll down and you'll see them.
francesb
« Reply #11 on: September 03, 2005, 03:44:18 PM »
huh, I didn't know that loudfastugly went out of business. Some friends and I went there once to get parts, and the visit ended with Brian yelling at us and kicking us out of the shop. well, he kicked my friends out--by that time I was in my car, engine running, ready to make a high-speed getaway.
I think he lived in that RV parked out front.
