Author Topic: CB750: Head Stud Removal  (Read 10901 times)
Offline Loudpipe
  • Broken Vehicle Collector
« on: July 16, 2008, 03:43:32 PM »
Anybody got any tips on how to get these out?  I read that they are loctited in, but I don't know if that's true or not.  Double nut trick sure doesn't work.
- LP
1974 Honda CB350F
Previous: 1978 Honda CB750F, 1971 Honda CB500K, 2009 Yamaha YZF-R1
Re: CB750: Head Stud Removal
« Reply #1 on: July 16, 2008, 03:46:36 PM »
Any combination of double nuts, vise grips, and/or stud remover with a dose of heat thrown in and soaking with penetrant.
Offline eurban
« Reply #2 on: July 16, 2008, 03:56:55 PM »
Search this subject.  It comes up often . . .
Offline Loudpipe
« Reply #3 on: July 16, 2008, 04:22:22 PM »
I did, and nothing came up.
- LP
1974 Honda CB350F
Offline bunghole
« Reply #4 on: July 16, 2008, 04:42:26 PM »
I used the bend and turn method.  Bend em down and turn them.  You'll have to replace them, but I assume you are since you are removing them.  There is some risk of them shearing off when doing this, but I didn't have any problems...other than sore hands.
'05 HD FLSTCI (Heritage)
'06 Suzuki DRZ400S
'08 Honda VFR800
'77 Honda CB750K
Offline scondon
  • Mmmm......tasty bugs
« Reply #5 on: July 16, 2008, 05:04:43 PM »
   I've adopted this method too. Seems they are less likely to shear this way than double nutting, or maybe it's the pounding with the hammer to bend them down that helps loosen them up. About a 35-40 degree bend seems good.
Offline SD750F
    • My Business Site
« Reply #6 on: July 16, 2008, 05:21:21 PM »
My machinist taught me to use heat and sweet Gulf Wax (used in canning) down the bolts before trying to twist them out. Worked great on all but the inside front four of my studs. Wonder why? Added heat? Mechanical location with additional or lack of surrounding aluminum? But after I started to "twist" the standard studs I decided to have the same machinist try. Will let you know how it comes out.
Scott
Offline Loudpipe
« Reply #7 on: July 16, 2008, 09:47:19 PM »
Is there such a thing as a stud remover?  There has to be.... While bending/heating/double nutting, and other methods may work just great, that can't be the proper way to remove a stud.
Wish I had a torch.  Maybe I'll get one of those small propane ones.  Should work.
- LP
1974 Honda CB350F
« Reply #8 on: July 16, 2008, 09:51:57 PM »
Are you removing them to go to 1/4 inch?
I have a stud remover that goes beside the stud and a knurled element cams over and locks to the stud, will try to check if it grabs these.
« Reply #9 on: July 16, 2008, 09:54:12 PM »
Stud remover, yes. I got mine at Sears I believe. Harbor Frieght wasn't as close. It works with your socket wrench. Wish I could post a picture. It has a "wheel" inside that grabs/snugs up against the stud so you can use the wrench to turn it.
Offline Big Jay
    • CBRzone
« Reply #10 on: July 16, 2008, 10:27:44 PM »
The best stud remover is from Snap On. Use it with a long extension on the ratchet and grab the stud as low as possible.
We prefer to smack the top of each one with a hammer as this helps shock the threads in the case and helps loosen them. We have never found it necessary to use heat.
About those new replacemants...   http://cbrzone.com/studs.html
Offline KB02
« Reply #11 on: July 17, 2008, 04:53:39 AM »
I've got one of these, too. Not sure yet how well it will work. I'll let you know in about two weeks. My new studs (Thanks, APE) will be here early next week and the week after I'll be able to start working on my engine again.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline SD750F
    • My Business Site
« Reply #12 on: July 17, 2008, 06:56:34 AM »
I have used the remover KB02 had a picture of... And it works okay, but was made for 10mm or larger studs. The smaller of the two stud location holes will not grab the reduced shaft of the standard 8mm studs properly with enough grab to work quite right. So I had to grab the top threads of my standard studs. And this is only good if you know you are going to replace all of them like I did...
Scott
Offline eurban
« Reply #13 on: July 17, 2008, 07:24:09 AM »
While there are stud removal tools, if you are doing this only once then you can get by with other techniques.  I double nut the top of the stud and use vice grips down low.  Use penetrating oil and then heat things up around the stud base. Have a friend turn either the top or the bottom while you turn the other.  Some bend over the studs and then turn them by hand.  Oh, and from the Tech Forums menu I searched for "stud removal" and had quite a few hits with useful info.  Discussions RE Heavy Duty studs inevitably discuss how to get the old one out.  There have also been a number of discussions on what to do if you break a stud off. . . .
Offline scondon
« Reply #14 on: July 17, 2008, 08:22:36 AM »
   Those things are good for typical removal. They will burr the shaft of the stud if it's stuck tight though. Do not grip them on the stud TOO close to the bottom end gasket surface as the large gear at the bottom will chew into aluminum like a hot knife through butter. Hold it level while you turn the wrench to make sure force is applied properly for removal, if it "cocks" on the shaft then you're more likely to snap a stubborn stud. If the stud does snap it is stuck in this tool and can be a real #$%* to remove from the tool.
   After snapping several studs with this tool I pitched it to the bottom of the tool box. I'll use it, just not on stubborn studs.
EDIT: Snapped studs were from the 4 "dry" holes in a F2 engine, rusted and in pretty frickin' tight. Not saying this tool is prone to snapping studs.
« Last Edit: July 17, 2008, 08:56:28 AM by scondon »
Offline RRRToolSolutions
  • I love old Japanese bikes!
« Reply #15 on: July 17, 2008, 01:03:08 PM »
Jay, Sean, I respect your comments and experience, but I personally have not had good luch without heat.
My old friend and long-time machinist Charles (maker of frame kits Charles) has worked on aluminum heads everyday for over 30 years and has never broken a stud. Me, I've done 6 motorcycle engines where I removed every stud and I've broken 2 off. The corrosion of 2 dis-similar metals and the fact the threads are different - somehow a more precise fit and you have recipe for broken studs. (I've screwed up a nice H2 case and original studs by using a regular tap and die to chase the stud and case threads - they had slop in them afterwards).
I wanted your APE studs installed in my CB750 hotrod project bike. Charles heated the block in an oven to 400 for about 10-15 minutes and removal was super easy. He used 2 Visegrips clamped near the bottom in opposing positions (12 and 6 o'clock) and turned then a half turn. The opposing force keeps side-load from adding to the stress the stud has during removal. I then took a socket and simply turned them the rest of the way using a ratchet and double nuts. The initial break was what made it safe.
According to him, you can use a torch or the oven - what you want to do is heat the aluminum block and not the studs. The studs don't heat up as fast since they are a lot more dense. Nowadays, I will try to get them out since it makes cleaning the gasket surface easier and I like to have them hard-chromed. In the case of my KZ900 project just done, I wanted to install APE studs, but if double nutting won't do it - then I leave them alone. If I had the cases apart, then in the oven they would go. Here is a complete set of "chromed" 1970 H1 studs - but heat was mandatory.
When they break - it's not pretty and not something an Easy-out tool is going to handle.
Regards,
Gordon
Kaws, Hondas, Yamahas, and Suzukis - especially Kaws
Offline scondon
« Reply #16 on: July 17, 2008, 01:45:38 PM »
Regards,
Gordon
Good info Gordon. I especially like the part about opposing vice grips :) :) :)
  Also like the part about heating the entire case in an oven. Using a hand held butane torch just didn't work for me. The aluminum case is so good at dissipating heat that in the time it took to set down the torch I could press my finger against the area around the stud without even thinking "ouch".
  *My limited experience with stud removal has me breaking it down into these categories:
Studs that can be removed regardless of method- 75%
Studs that need heat, impact, or other TOT's-        20%
Studs that will snap no matter what voodoo you practice- 5%
*Warning: this is just an opinion and is subject to change at manufacturers discretion ;) ;D
Offline Gamma
  • Bike Magazine august 1980 page 71. me on my F1
« Reply #17 on: July 17, 2008, 01:52:22 PM »
I used your technique Gordon after researching the postings.
Heated the case in the oven, 2 pairs of Mole grips low down opposing each other, (got a mate to hold it down on the bench with oven gloves) and double nut at the top to undo each one after initial movement.  Whilst cleaning the threaded holes in the case, I also hacksawed a vertical slot in one of the removed studs threaded area, to make a thread chaser.
« Reply #18 on: July 17, 2008, 09:55:35 PM »
You guys are missing 2 major points here
The success of removing studs or bolts depends GREATLY on insuring no aluminum comes out with them.. So the first step after cracking it loose depends on moving it back and forth to make sure this does not happen..
You said you ruined threads by chasing with a tap.. which tap.?? Taps are ground to thread limits and you should use a good one, not whatever is handy.. cheap taps are not even ground threads, and are of poor tolerances..
Offline ksmith0034
  • When I grow up I want to be a
    • Please subscribe to my motovlog
« Reply #19 on: July 18, 2008, 05:26:05 AM »
I just replaced my studs recently.  They were ALL stuck, so I first shot PB Blaster down into the threads and let it sit a day or so (PB Blaster is the greatest stuff since sliced bread-check it out).  Then, after TIGHTLY double nutting, my buddy carefully heated the block, (NOT the studs!!!) as I slowly backed out each stud using the lowest setting on my impact.  They all came out like butter.  Just take your time and don't force anything.  The last thing you want to do is twist one off!  BTW, don't forget to replace them with heavy duty studs like APE.  They are a lot beefier and won't stretch like stock studs.  You don't want any leaks!
It took 10 years but she's finally done!
Stocker 2 Rocker CAFE conversion
My YouTube channel HERE:
https://www.youtube.com/MotoCafeRacer
« Reply #20 on: July 18, 2008, 06:10:01 AM »
 I'm with Gordon and Gamma on this one....I use heat. I use a thread chaser....NOT a tap to clean the holes out. There is a difference between the two tools.
Offline Gamma
Offline scondon
Offline bunghole
« Reply #23 on: July 18, 2008, 10:38:37 AM »
I'm kicking myself for throwing my bent ones out!
Where can I find a good set of thread chasers?  I've been looking all over the place and can't seem to find a set.  All I can find are taps which I already have.
'06 Suzuki DRZ400S
'08 Honda VFR800
'77 Honda CB750K
« Reply #24 on: July 18, 2008, 11:18:31 AM »
Craftsman, Snap-On or Mac. They all look to be the same item in all honesty (the Snap-On is their Blue Point line). They are an excellent addition to a tool collection.
