Author Topic: oil filter change techniques?  (Read 2697 times)
Buffo
« on: September 02, 2005, 07:29:24 PM »
I am thinking of removing my header when I chande my oil filter. the filter housing just barely fits between the pipes and gets oil all over them. And it is apin in the ass getting the bolt lined up...I fear I may cross thread it one day.
Plus I just painted my header and dont want to scratch it all up...they rust fast enough!
What do you folks do...
BTEAS
eldar
Re: oil filter change techniques?
« Reply #1 on: September 02, 2005, 07:33:02 PM »
I just go slow. When unbolting the housing, let it sit a bit and the oil will drain down the housing. Sure it is messy on the housing but when it is done, I dont have to worry about gunking up my headers. I guess I have never had a problem so i never thought about it.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #2 on: September 02, 2005, 07:56:55 PM »
I agree putting it back on is a pain, but if you press the entire housing against the lower case as you start the bolt it helps overcome the spring wanting to push the filter core out so the bolt threads don't want to catch.
« Reply #3 on: September 02, 2005, 08:22:27 PM »
Hi stupid, how ya doin.
Don, would one of Terry in Aus screw on adapters make the job a bit easier?
Sam.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #4 on: September 02, 2005, 08:24:23 PM »
« Reply #5 on: September 02, 2005, 08:35:31 PM »
Thats what he Christened himself last week. ;D
« Reply #6 on: September 02, 2005, 08:38:22 PM »
Meaning Don not you Bob,  sorry, ::)
Offline kghost
« Reply #7 on: September 02, 2005, 09:18:17 PM »
I second the push the housing against the case.
Use a ratchet after you crack the bolt loose.
The push against the case trick works taking it off too. That way the oil dripping is kept to a minimum.
Stranger in a strange land
Offline mcpuffett
« Reply #8 on: September 03, 2005, 03:09:48 AM »
hi buffo, i have a spin on filter it is easier to get on and off but you still get some spillage on your headers  ;)  mick.
Offline jotor
« Reply #9 on: September 03, 2005, 06:09:16 AM »
Personally, I never use the c-word anytime I'm working on a motorbike.......
I'd rather ride a Yamaha than eat worms.
Gallery.....http://www.sohc4.us/forums/index.php?topic=2254.0
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #10 on: September 03, 2005, 08:35:46 AM »
But I have uttered the f-word once or twice.  ;D
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #11 on: September 03, 2005, 10:11:42 AM »
There is an oil drain bolt at the bottom of (the filter housing) on the engine. Draining the filter before removing will certainly help with the oil mess.
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #12 on: September 03, 2005, 10:49:05 AM »
Oil drain bolt in the filter housing??
Is this something I've missed for the last 30 years??
SOHC4 Member #2393
1971 CB500K0 (US Model)
All modern bikes now gone...
Offline clarkjh
  • Expert? If only.
  • Surely and Samson are now Co-habitating
« Reply #13 on: September 03, 2005, 11:10:54 AM »
I'm with Buffo
The PO made a custom pipes and didn't leave room for the filter housing to pass thought the header, so I have to remove my headers.  Gona have to get one of the coolers and spin on addapters from Oz.
James
SOHC/4 #3328
SOHC/4 Gallery: http://www.sohc4.us/gallery/v/members/personal/clarkjh/
1974 CB550, 40000 Miles
1980 GL1100, 102789 KM - Back on the road after a complete engine rebuild.
*** Why, oh why, is it always head gaskets with me?***
