Author Topic: Perpetually loose chain...  (Read 1690 times)
Offline Lumbee
    • My pics...
« on: September 03, 2005, 09:54:51 AM »
...I've had my 750F for about 6 months now. and it seems every 2 months or so, the chain is back to being slack again, and I have to readjust it.  I don't think the chain or sprokets are overly worn, however I don't know how long they have been on the bike.  I do know the chain does NOT have loose spots in it.  Is this normal?  Any info appreciated...
"I'm not a welder, but I play one on HondaChopper.com"
Offline Killer Canary
  • Typical Bran Muffin
Re: Perpetually loose chain...
« Reply #1 on: September 03, 2005, 11:22:20 AM »
How many miles are two months? My chain loosens up enough to need adjustment in 300-500 miles.
Kawi GPz900, H1
Offline Lumbee
    • My pics...
« Reply #2 on: September 03, 2005, 11:46:40 AM »
...I don't put alot of miles on it...I fill up the tank probably once a month.  But most of those miles are tooling around town...so I'm sure that is tougher on it...
« Reply #3 on: September 03, 2005, 12:39:05 PM »
How often do lube the chain and what type of lube are you using?
Is this an oring chain or standard?
A new chain will rear faster (certainly initially) on used sprockets as it wears in to the worn spacing of the old sprockets.
Offline Lumbee
    • My pics...
« Reply #4 on: September 03, 2005, 12:45:39 PM »
...I admit I probably havn't taken very good care of the chain.  It wasn't to bad when I got the bike, so I've only sprayed it with some PB Blaster.  How do I tell if the chain is Oring or standard?
Offline Lumbee
    • My pics...
« Reply #5 on: September 03, 2005, 04:28:04 PM »
hmm..not sure (even w/the pics)...mine does have a removable link...does that tell me anything?
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #6 on: September 03, 2005, 04:37:41 PM »
On the standard chain, the side plates rub up against one another. On an O-ring, the side plates are separated by, well and O-ring. The tend to be somewhat wider because of this, so clearance on the front sprocket in particular can sometimes be an issue on older bikes.
Offline Lumbee
    • My pics...
« Reply #7 on: September 03, 2005, 05:46:55 PM »
...looks like I have a standard chain then...
Offline Uncle Ernie
« Reply #8 on: September 03, 2005, 06:07:34 PM »
Hey Loco- nice pix!
