Author Topic: installed new exhaust, now electric start doesn't work  (Read 2017 times)
francesb
« on: September 03, 2005, 03:37:19 PM »
Hey all,
So, I broke down and paid the car mechanic on the corner $60 to install my exhaust, the old bolts were too stripped for me to remove, and I couldn't drill out the fastener thing on the silencer. So, a reasonable amount of money well spent, bike looks and sounds much better.
Except, now the electric start doesn't work. I don't see anything that appears to be loose. What could he have done? Or is it a coincidence?
Buffo
Re: installed new exhaust, now electric start doesn't work
« Reply #1 on: September 03, 2005, 03:50:54 PM »
what year/model
francesb
« Reply #2 on: September 03, 2005, 03:53:25 PM »
pffff.
It's a 73 CB750. .
Buffo
« Reply #3 on: September 03, 2005, 03:55:20 PM »
have you tried to start it with the clutch pulled in?
francesb
« Reply #4 on: September 03, 2005, 04:02:11 PM »
yeah, I tried that. It makes a slight almost-buzzing sound with or without the clutch pulled in.
Offline Jonesy
  • Shop Rat
« Reply #5 on: September 03, 2005, 04:10:46 PM »
Will it at least kick start? Sounds like the buzz from the starter when the battery is tired. (Just narrowing stuff down)
francesb
« Reply #6 on: September 03, 2005, 04:15:11 PM »
Kicks over on the first try, and the lights/horn are strong. I don't think its the battery.
Buffo
« Reply #7 on: September 03, 2005, 04:18:29 PM »
I have no Idea of how to fix your problem...
Offline Bodi
« Reply #8 on: September 03, 2005, 04:40:43 PM »
If it's buzzing from the solenoid switch, there's a bad connection somewhere in the solenoid circuit or the solenoid itself is jammed.
Checking the small wires on the solenoid with a voltmeter will tell you which. If it has about 12V on one wire and 0V on the other when the starter button is pressed but it still isn't starting (turning over) then the solenoid is stuck.
If the solenoid gives a nice clunk when the starter is pressed and the buzz comes from the motor, you might have a motor problem but it could still be the solenoid. Jamming a screwdriver between the two big stud terminals on the solenoid will energize the motor for sure and tell you if it is fine.
The solenoid is serviceable, you can remove and disassemble it. Disconnect the battery first, there's no fuse in the big power wire and it will touch the frame when removed. Clean the contacts - the copper bolt heads and the copper bar contact. Clean and lightly lube the moving parts. Should work.
The motor has replaceable brushes but I've never seen one need them.
I suspect a wiring problem. I don't know why or how working on the exhaust would do that but strange things happen.
Offline clarkjh
  • Expert? If only.
  • Surely and Samson are now Co-habitating
« Reply #9 on: September 03, 2005, 04:45:26 PM »
check the main feed from the starter to starter solenod, should be with the rest of the goodies, (fuses, rectifier, ect).  Sound like there is a short to ground in this wire.  I had the same problem on my 74 550 when I pull the left hand cover to check my oil sensor, and crimped the wire when I put the cover back on.  Also took me two weeks to find the problem.
Hope this helps.
James
SOHC/4 #3328
SOHC/4 Gallery: http://www.sohc4.us/gallery/v/members/personal/clarkjh/
1974 CB550, 40000 Miles
1980 GL1100, 102789 KM - Back on the road after a complete engine rebuild.
*** Why, oh why, is it always head gaskets with me?***
« Reply #10 on: September 03, 2005, 11:34:59 PM »
Could be starter, could be solenoid as mentioned above.
Could also be the push button in the bar control, particularly if the master cylinder has leaked brake fluid into the switch housing.
Does your headlight still function correctly?  The starter and the headlight can be affected with that starter button switch.
Offline Jonesy
  • Shop Rat
« Reply #11 on: September 04, 2005, 02:03:15 PM »
Mine did too. I looked at the battery and found one cell low on water. Everything else on the bike worked fine, but it didn't have enough oomph to roll it over.
francesb
« Reply #12 on: September 04, 2005, 07:20:41 PM »
thanks, jonesdp. that was the problem.
Offline heffay
« Reply #13 on: September 04, 2005, 08:36:07 PM »
hoooray for jones!!!!! :-*   we love you
Offline Jonesy
  • Shop Rat
« Reply #14 on: September 05, 2005, 05:10:04 AM »
No prob, glad I could help. :)
I love it when the cause is something simple- saves a lot of grief!
