Author Topic: '77 550F Passenger Seat Strap Hardware  (Read 934 times)
Offline psykod
« on: July 22, 2008, 10:25:50 PM »
Does anyone know where I can get a new set of passenger seat strap brackets and screws that bolt the strap to sides of seat?  I've lost the chrome on mine and need a new set.  I could have them rechromed but I think it will be cheaper to buy a new set.  I didn't see them listed in the Honda parts fiche (only as part of the entire seat assembly).
« Last Edit: July 23, 2008, 05:48:34 AM by psykod »
1977 CB550F.  Mostly Stock.
Offline kent400
Re: '77 550F Passenger Seat Strap Hardware
« Reply #1 on: July 24, 2008, 12:44:42 AM »
I would have thought a company who specialise in seat restoration could help with the seat strap brackets. They are however available in the U.K. from R K Leighton ( www.rk-leighton.co.uk ) I bought some for a 400f, £8 the pair (about 16$), not sure if they have the screws but I imagine they have. For the screws I used a pair of bright zinc plated cross head headed ones, the same type as used on the engine case. The original screws have a shoulder that locates in the seat frame so a turned down a piece of tube to fit over the screw and into the seat frame. I just stuck the tube on the screw with some epoxy adhesive. Whilst they are not chrome they are bright enough.
Offline MrZxp
« Reply #2 on: July 24, 2008, 03:38:24 AM »
For my 550, I got one of these off ebay...
http://cgi.ebay.com/ebaymotors/HONDA-CB77-CL77-CB450-CB350-CB750-SEAT-STRAP-BUCKLES_W0QQitemZ380043501899QQcmdZViewItem
Probably wouldn't hurt to replace the whole strap too while you're at it.
I posted a question to the outfit first, detailing the length of strap I required. They were most helpful and I received it promptly (for being in NZ that is). It required cutting to the exact length I needed but that was not difficult and it looks great!  :)
Sorry, no pics, bike is stored away for the winter.
Cheers, Phil
« Last Edit: July 24, 2008, 03:47:43 AM by MrZxp »
09 Boulevard M90
SOHC4 Member #3336
Offline psykod
« Reply #3 on: July 24, 2008, 06:05:50 AM »
Thanks, I'll look in to that.  Unfortunately, I already had the strap made by a local upholstery shop for about 15 bucks.  I guess it wouldn't hurt to have a spare laying around.
