Author Topic: DOES ANYONE DRAG RACE THESE CB750'S ????  (Read 6940 times)
grizzzly
« on: July 27, 2008, 03:40:13 PM »
I HAVE MY FIRST CB750 IT'S A 72 & I LIKE IT BUT I'M GONNA BOBBER IT OUT. JUST NOT ME THE WAY IT IS. I AM PICKING UP A 75 CB750F OR SS (NOT SURE WHICH IT IS) PARTS BIKE, DIRT CHEAP, THAT RUNS & HAS SOME REALLY NICE PARTS ON IT. IT HAS A 4 INTO ONE PIPE, KONI SHOCKS AND SOME OTHER STUFF THAT I WILL PUT ON MY 72. BUT I'M THINKING I MIGHT TRY TO MAKE THE 75 INTO A STREET/STRIP BIKE, REAL LOW & DRAGBIKE LOOKING. I'M NOT LOOKING TO GO 9'S OR AIR SHIFTED OR ANYTHING LIKE THAT, BUT SOMTHING SORTA DRAG RACY, BUT DRIVABLE ON THE STREET. I WILL DRAG RACE IT HARD THOUGH, FULL THROTTLE LAUNCHES ON THE WHEELIE BAR , BUT I WANT TO FOOT SHIFT IT. ANYBODY OUT THERE WANNA GIVE SOME MORE IDEAS ? I WOULD MODIFY THE MOTOR SOME BUT NOT TOO MUCH, YOUR THOUGHTS ??? THE CLUTCH IS SOMETHING I'M NOT SURE OF THOUGH, WOULD HAVE TO HANDLE THE HARD LAUNCHES & DRIVING ON THE STREET. SEND ME SOME PICS OF YOUR BIKES TOO. THANKS, JOHN
Re: DOES ANYONE DRAG RACE THESE CB750'S ????
« Reply #2 on: July 28, 2008, 07:18:37 PM »
Cool, what was the time/speed? Looks like it just turned double digits at the end but I can't make it out. 10 or 11 secs? Fastest i've ever gone was a 12.76. Hope to do better with Phaedrus II.
« Reply #3 on: July 28, 2008, 07:30:16 PM »
It runs 12.0s with terminals around 112mph.
here's another vid with different pipe and streamlining.
Sam. ;)
Offline scondon
  • Mmmm......tasty bugs
« Reply #4 on: July 28, 2008, 07:53:02 PM »
 Tell Chris not to pitch that old fairing he doesn't use. I'll pop by and take it to the recyclers for him ;) :)
« Reply #5 on: July 28, 2008, 07:57:16 PM »
 ;D ;D ;D ;D ;D ;D ;D ;D
Sam. ;)
« Reply #6 on: July 28, 2008, 08:01:49 PM »
no wheelie bars.. way too much heat & they look silly on a 12 sec bike.
 Stretch the swingarm... and use struts.
 really low gearing(cheaper than engine mods)
 Stiffen your forks, like 40 wt, or strap it.
 Lower it, at least on the track.
Online MRieck
« Reply #7 on: July 28, 2008, 08:03:20 PM »
I'll bring it home with me Sean and send it to you. It should fit in the carry on.
« Reply #8 on: July 28, 2008, 08:12:37 PM »
I don't give a toss as long as you keep your hands off the RS ;D ;D ;D ;D ;D ;D ;D
Sam. ;)
« Reply #9 on: July 28, 2008, 08:15:39 PM »
Stock clutch and springs up to now. We have a set of Barnett springs but have not needed to use them yet.
Sam. ;)
Offline scondon
« Reply #10 on: July 28, 2008, 11:45:10 PM »
    I'll ride over and install it at your place ;) ;D ;D ;D
Offline Kev Nemo
  • Honda Hacker
  • http://fallingapartart.com/
    • FallingApartArt
« Reply #11 on: July 29, 2008, 05:49:04 AM »
Sam. ;)
Love the sound of the full fair in this vid-what's the exhuast set-up?
Destroyed by Design since 2009 http://fallingapartart.com/
- '78 CB750k bobtrack
« Reply #12 on: July 29, 2008, 11:38:59 AM »
It's not the Honda you can hear Kev, It's the GSXR in the right lane. (the one that came second ;D ;D ;D ;D)
Sam. ;)
Offline Kev Nemo
  • Honda Hacker
    • FallingApartArt
« Reply #13 on: August 05, 2008, 09:30:21 AM »
I'm pretty sure it's the Honda-it doesn't come on til launch. Would be a straight pipe?
Offline DsKing416
  • Trying to smile.
« Reply #14 on: December 21, 2009, 05:30:25 AM »
Port the hell out of the head. You can have 1.8 mm milled off the head deck for way higher compression. Put in some CV carbs, You need to set your gearing so that you are topped out in fourth at the end of the run the more you shift the slower your time. Lengthen your swingarm and set the bike as low to the ground as safely possible. Should shoot straight and turn heads on the street too.
« Reply #15 on: December 21, 2009, 09:12:04 AM »
   1.8 MM... :o   :o   :o
Online MRieck
« Reply #16 on: December 21, 2009, 10:13:15 AM »
   1.8 MM... :o   :o   :o
That is a lot
« Reply #17 on: December 21, 2009, 10:19:19 AM »
I think that would eliminate any "drop in' Piston kits..more machining...
Offline Old Scrambler
« Reply #18 on: December 21, 2009, 12:07:50 PM »
That's one less camchain link for sure and maybe two!  Assuming stock pistons.  Is that correct for an F2 motor?
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline sparty
  • I just play one on TV
  • My engine is 100% stock... wink.
    • Gallery
« Reply #19 on: December 21, 2009, 12:56:54 PM »
Yep.  I drag mine.  It is also built for the street, so it serves two purposes.  Fun to drag and ride on the street.  If you are going to drag it be sure the motor is stoutly built or you will be rebuilding it.  I run in the 11s with mine and I am still a rookie on the strip.
Art
1972 CB750 K2 Cafe' Style
GO AWAY SNOW AND COLD!  Can you see the Hot Rod wants to run...
“That's thirty minutes away. I'll be there in ten.”
Offline NitroHunter
  • Radical Street / Strip Turbo
  • A man's motorcycle is a reflection of the man
« Reply #20 on: December 21, 2009, 01:07:19 PM »
Air shifters are wonderful. Your tranny will thank you for using one everytime you power shift...
Robbie the NitroHunter                      Fuel Coupe Hired Gun                  NHRA T/F 640
DRAGBIKE USA XH/MB Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=127179.0;attach=332735
DRAGBIKE USA XH/SS Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=63940.0;attach=103300
Young mans glory days in the lanes: http://forums.sohc4.net/index.php?action=dlattach;topic=45685.0;attach=66341
Offline DsKing416
  • Trying to smile.
« Reply #21 on: December 21, 2009, 07:44:57 PM »
I will double check my measurement for that motor tomorrow with my machinist. A heavy cam degree is also required. But stock pistons, stock gaskets, stock connecting rods. Just barely missing the valves is the key. Big bore power just by shaving the head. He shaved my cb550 now running a 12.2:1 compression ratio.
Offline bucky katt
  • i am a pastafarian!
    • facebook
« Reply #22 on: December 21, 2009, 09:23:43 PM »
obviously not street ridden then?
Mark Twain - Notebook, 1894
Offline DsKing416
  • Trying to smile.
« Reply #23 on: December 22, 2009, 06:17:10 AM »
No it's my daily driver, ;D it's the bike in my avatar, it screams. I'll get you those numbers in an hour or so. I work for an AMA superbike team so I'm just gonna ask the engine builder. He's at work today.
« Last Edit: December 22, 2009, 06:24:36 AM by DsKing416 »
Online MRieck
« Reply #24 on: December 22, 2009, 06:31:53 AM »
Art
How many times have you had it at the strip Art? Also...what was you best mph??
