Author Topic: Measuring Fuel Pressure?  (Read 2122 times)
Offline De La Nooch
« on: August 01, 2008, 12:45:02 PM »
Would I be able to use a tool like this: http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=92699 to measure the fuel pressure in the line coming from the tank?  I see a fitting in there that I could use with some spare hose to tap directly into the petcock and simulate normal fuel flow.
Thanks for any advice. Not quite as techinically inclined as I wish I was... :)
-Jordan
1975 CB550K.
Offline Steve F
Re: Measuring Fuel Pressure?
« Reply #1 on: August 01, 2008, 12:48:13 PM »
Unless you're using a fuel pump of some kind, there is no pressure on an SOHC/4 (gravity feed).
Offline De La Nooch
« Reply #2 on: August 01, 2008, 01:02:17 PM »
I understand that it is gravity fed, but isn't there still some pressure in the lines?
Doesn't gravity combined with a large amount of fuel in a large tank going into a small outlet create pressure?
-Jordan
1975 CB550K.
Offline rbmgf7
  • 2>4
« Reply #3 on: August 01, 2008, 01:26:42 PM »
the amount of pressure is insignificant. listen to steve: it's gravity fed.
Offline De La Nooch
« Reply #4 on: August 01, 2008, 01:31:04 PM »
Once again, I understand that it is a gravity-feed system.
But what you are saying is that there is absolutely no pressure, as in 0.0 PSI, in the fuel lines? Seems hard to believe...
-Jordan
1975 CB550K.
« Reply #5 on: August 01, 2008, 01:39:14 PM »
Of couse there is some pressure in the lines due to gravity. Also the level of the tank would effect presssure at the petcock opening. If you are equating flow to pressure, you would be better off with a measuring cup and a watch to do that.
« Reply #6 on: August 01, 2008, 01:52:41 PM »
There IS a measureable pressure in the fuel lines.  It is very small.  You can make far more pressure (or vacuum) with your mouth, btw.
The pressure calculation requires knowing the cross sectional area of the oultet (lets assume the tubing inner diameter), and then extending that area up to the surface of the fluid, forming a column.  The weight of the volume inside that column is the head pressure.
For most of our SOHC fours, you can simulate this head pressure with a simple drinking straw, the same height as the distance from carb inlet valve to the fuel top surface (maybe a Foot?), and filling it with water.  Note that pressure at the bottom outlet of the straw reduces to zero as the fluid level in the straw reduces.  We're talking grams weight here, in the 5-10 range.  I estimated a 50 gram force per centimeter input to a converter, and got 0.71 PSI.  This would be with a full tank of gas.  The number would get smaller as the tank empties.
To answer the original question, no, the Harbor freight tool isn't going to be very helpfull in measuring carb fuel line pressures.
Another thing to observe, is the cab needle valve spring strength.  Pretty tiny and easy to compress, yet it is more than enough needed to stop a full tank of gas from entering the carb.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #7 on: August 01, 2008, 03:29:08 PM »
Why is knowing this important? Just curious.
« Reply #8 on: August 01, 2008, 03:48:25 PM »
No pencils or paper were harmed in the making of this diatribe. ::)
 ;D
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #9 on: August 01, 2008, 05:13:22 PM »
 ;D
I actually directed it to the original post about wanting to measure the pressure. I could have been a little clearer.
« Reply #10 on: August 01, 2008, 05:35:14 PM »
I think he was trying to determine flow rate.
Offline jtb
  • An unlikely
« Reply #11 on: August 01, 2008, 08:34:39 PM »
Damn, Lloyd, I remember studying this stuff back in the early 60's.  How in the hell do you remember it?
 ;D ;D ;D ;D ;D ;D
1977 CB750F
1985 V65 Sabre
« Reply #12 on: August 01, 2008, 08:58:25 PM »
 ;D ;D ;D ;D ;D ;D
I don't know.  I've always wondered if it was a blessing or a curse.  :-\
Do you suppose it's an indicator, that I've been cursed at more often than blessed at?
Offline De La Nooch
« Reply #13 on: August 02, 2008, 04:21:44 AM »
Thank you all, especially TwoTired, for the replies. This is exactly the type of information I was looking for.  ;D
I am toying around with ideas for a project/experiment on the bike. This was just a curiosity that was raised.
-Jordan
1975 CB550K.
