Author Topic: Removing rust from behind rim strip  (Read 3379 times)
Offline alltherightpills
« on: July 28, 2008, 07:28:45 PM »
Friends-
I just got a new set of tires (Avons) and started the process of changing them tonight.  When I got the tire off I noticed a fair amount of rust both behind the rim strip and around it.  In searching I came across TT's advice to use a zinc chromate primer once I have removed the rust, so that is what I am planning on doing once the rust is gone.  As per removing the rust I was wondering if the molasses concoction that folks use to get rust out of their tanks would work for removing the rust on my wheels, or would I be better off using a wire wheel?  I am guessing that the mixture is too liquidy, for lack of a better word, to use on the wheels, but I thought I would check to see what you all thought.  Also, any other advice for making sure the rust stays gone once I remove it?
Thanks in advance...
« Last Edit: August 02, 2008, 10:08:48 AM by alltherightpills »
78 550K
77 550K (in pieces)
71 500K0 (in pieces)
Re: Removing rust from behind rim strip
« Reply #1 on: July 28, 2008, 07:45:13 PM »
I wired wheeled off the loose rust. Used a rust reformer to change the remaining rust and painted the inside with a two part epoxy paint to try a seal around the spoke ends to slow down new rust. Water will get in eventually through the spokes, but I want to slow it down. I used the old tube as a rim strip since it was better rubber and thicker.
Offline hymodyne
« Reply #2 on: July 28, 2008, 07:46:33 PM »
my rims had been outside for quite a while when I got my bike, and  they were rusty inside. I bought the spray or brush on product that is supposed to convert rusted metal into something paintable and used it on the inside strips of both rims before I put the new wheels back on.
hym
Offline gar
  • '75 CB550
« Reply #3 on: July 28, 2008, 07:53:35 PM »
Good idea about the epoxy paint.  When I put new tires on two years ago, I used a wire brush to remove the loose rush, sprayed the rusted area with Permatex brand rust treatment, put a new rim strip in, and I was finished.  I did not have extensive rust, though.... just a few bad areas underneath the old rim strip.
In hindsight, a coat of paint like bobby suggests would be a good idea.  I don't know if it is necessary, though.
Regards, Gary
Don't use a big word where a diminutive one will suffice.
Offline toycollector10
« Reply #4 on: July 28, 2008, 09:14:13 PM »
I used a circular brass brush in an angle grinder to softly remove all the rust then painted with rust killer. Quick and easy.
1969  CB 750 K0
1973  CB175
1973  Z1 Kawasaki
Offline Clyde
« Reply #5 on: July 28, 2008, 10:38:07 PM »
I use a 6 inch wire brush wheel on my bench grinder to remove the rust, then paint with a cold gal/zinc rich paint
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
« Reply #6 on: July 29, 2008, 05:59:44 AM »
Thanks for the info and ideas fellas.
I didn't think it would be possible to completely seal the rim from the elements, but I like the idea of using the old tube for a rim strip and using an epoxy to seal off the spoke ends.
And the more I think about it, the more I think it will be easier to just use a wire wheel and sandpaper than it will be to use the molasses concoction.
Thanks for the tips,
Zach
78 550K
77 550K (in pieces)
Offline goon 1492
  • Sucka Repellant
« Reply #7 on: July 29, 2008, 06:41:43 AM »
or instead of using sandpaper use a 3m scotch brite pad it will get into the crevases(spelling?) better. 8)
