SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
"NEP nylon rear sprocket"
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: "NEP nylon rear sprocket" (Read 2363 times)
Markcb750
Guest
on:
July 31, 2008, 05:12:14 PM »
There is a great article in another thread about things to improve the CB 750/
I am replacing my tires and would like to cure a rear sprocket "wobble" issue this weekend. (I have about 0.05" run out (TIR) parallel to the axle...might be axle?)
The Motorcyclist August 1981 article lists "NEP nylon rear sprocket" which I cannot find reference to here in FAQ or on Google. Might be a good modification to perform while I have the 750 apart.
Anyone have a experience with this modification?
Last Edit: July 31, 2008, 05:20:30 PM by Markcb750
Logged
super pasty white guy
I'm not really a
Expert
1976 750 F
Re: "NEP nylon rear sprocket"
Reply #1 on:
July 31, 2008, 05:28:35 PM »
I too saw that and wondered if they were still available. Didn't find that they were, but found a report of them melting from the heat of an incorrectly lubed chain.
I'll be interested to see if these were/are used by any members here.
spwg
Logged
MRieck
Really Old Timer ...
Big ideas....
Reply #2 on:
July 31, 2008, 07:14:55 PM »
I bent the crap out of one of those with an 811 Yosh kit.
I was doing burn outs.
They have been long out of production.
Logged
micol
Full Member
Reply #3 on:
July 31, 2008, 08:15:46 PM »
PUT ONE ON A CBX ONCE. DID ONE BURNOUT AND SHEARED EVERY TOOTH ON IT.
Logged
754
Reply #4 on:
July 31, 2008, 09:36:53 PM »
Now you know why you dont see them anymore..
Bent axle wont make sprocket run out.. try cleaning behind the sprocket, or shimming. Also your cush drive may not be seating properly..
Logged
Kelowna B.C. Canada
fuzzybutt
Guest
Reply #5 on:
July 31, 2008, 09:51:47 PM »
aluminum sprockets are the ticket now.
Logged
Raul CB750K1
Old Timer
Reply #6 on:
July 31, 2008, 10:56:10 PM »
We talked about nylon sprockets a while ago....
http://forums.sohc4.net/index.php?topic=17737.0
Logged
Markcb750
Guest
Reply #7 on:
August 01, 2008, 02:37:10 AM »
Thanks guys. I will pass on the plastic sprocket this weekend.
O'ring chain & new sprockets.(fix wobble).
New Bridgestones & tubes
tune spokes.
34% of cost of CB with out labor....
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
