I just got my 750k8 up and running and twice now I have been out on test rides and lost my idle air screws. First #3 fell out and I was left with the spring on the transmission so I limped home on 3 cylinders. The second time #2 screw fell out on the highway I lost some power, then when I stopped to turn around it stalled. I found the screw sitting on the transmission but the spring was lost so I screwed it in and limped home again. Is there a trick or tip to solve this very annoying problem? I would hate to loose the adjustment and just lock-tight them, but I don't have many parts left from the carb rebuild.
Also on ride #2 (30miles) I found that the sides of the engine at the head gasket are seeping oil. I am using Rotella T SAE30, is this the reason?? If not is there anything I can do other than replace the gasket?
Any help would me great.
Oh and here is a pic of the bike, still need to do some buffing.
So far I have rebuilt the carbs, tune up, removed Vetter fairing, crash bars, and luggage rack, rebuild front brake, 530 18/48 chain sprocket change, blade fuse holder, repaired cracked side cover, repaired seat (gorilla glue is the best!!), full fluid change, and scrapped 30 years of grease and dirt off everything.
By the way all of the above jobs were completed with the help of the archived threads, thank you all.
