Author Topic: So, 750 rear end swap onto cb550  (Read 969 times)
Offline sinister902
    • Anger Street Kustoms
« on: August 04, 2008, 04:11:29 PM »
having an issue here.....at first glance, i thought i could just swap the rear sprockets, but the bolt patterns are much different, and the cb550 rear is 37teeth, while the 750 is 48teeth.....and at that large of a jump.....where i used to be at 75mph on the 37 tooth, the 48tooth will put me UNDER 40MPH!
so, I'm assuming im not the first to attempt this, and was wondering what others have done to remedy this situation....
Offline JS550
  • the artist formerly known as
  • IAFF local 1307
Re: So, 750 rear end swap onto cb550
« Reply #1 on: August 04, 2008, 05:56:28 PM »
I asked a similar question here a couple of days ago! I know what your thinking, great midrange, little slow off the line! Me too. Anyway, someone gave me a website,Sprocket Specialists. They have what youre looking for. There is an article also here on SOHC about hopping up the 550 and it says go up like 4 or 5 teeth. Hope this helps.
If you're worried about how many calories are in beer, is losing weight really your biggest problem?
Offline sinister902
« Reply #2 on: August 04, 2008, 07:44:45 PM »
Thanks! i actually jumped on oldbikebarn.com on a wim....and found a 39 tooth sprocket for the CB750, so i ordered it for $40 shipped, which is 2 teeth more than the 37tooth stock 550 sprocket.....so im stoked...
Offline dusterdude
« Reply #3 on: August 05, 2008, 10:09:46 AM »
i hope you get it
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline sinister902
« Reply #4 on: August 05, 2008, 08:23:26 PM »
what do you mean? bad service with them?
If all else fails I used my credit card, so I could always dispute the charge and have my money pulled back.....
