Author Topic: which gasket?  (Read 879 times)
keener
which gasket?
« on: August 05, 2008, 02:29:45 PM »
Hello I have recently discovered a leak and I don't know what gasket is leaking. It looks like its coming from the drive sprocket opening? what gasket would that be? hopefully I don't have to take out the engine to replace it. thanks for any help
Offline scunny
  • don't call me expert
Re: which gasket?
« Reply #1 on: August 05, 2008, 02:37:57 PM »
pull the sprocket cover, it doesn't/ shouldn't hold oil and have a look. could be the sprocket shaft seal, or if it's a 750 you might have an auto chain oiler
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
keener
Re: which gasket?
« Reply #2 on: August 05, 2008, 02:39:07 PM »
it a 77 550 and Ill have to wait to pull the side cover till it cools down, I just cant find a diagram of the left side of the engine to see where the gaskets are...
keener
Re: which gasket?
« Reply #3 on: August 05, 2008, 03:54:31 PM »
could it be coming from the shifter shaft. I stripped the last screw as i tried to get it out and now i have to take it to honda since I have no way of getting it out... :-\
Re: which gasket?
« Reply #4 on: August 05, 2008, 08:47:23 PM »
Shifter shaft seal
oil pressure switch
oil pump cover O ring---NOT AVAILABLE FROM HONDA
