Author Topic: engine teardown questions  (Read 978 times)
xProjectx2501
« on: August 05, 2008, 02:45:07 PM »
How fitting that I finally have a day off to work on my bike and I have a question before I can really dig in to it! I'm about to start tearing down my engine so I can do the full gasket/cylinder/piston restoration and wanted to know if there are any things I should watch out for while disassembling. Also, it's supposed to rain in the next few days and the bike is sitting in my garage. Should be worried about engine components being exposed to humidity like that?
Thanks in advance!
martino1972
Re: engine teardown questions
« Reply #1 on: August 05, 2008, 02:49:12 PM »
yes,do not break a part of the main engine case off(says the man that sits here,jelling in dutch after he just broke an engine case to pieces on a honda 400 quad engine rebuild for a costumer while reassembling...)
Offline scunny
  • don't call me expert
« Reply #2 on: August 05, 2008, 02:52:18 PM »
just be organised, take notes, and undo case, head and cover bolts as per manual to prevent warping.
if you are worried about the humidity, lightly coat parts with oil
goodluck
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #3 on: August 05, 2008, 03:54:42 PM »
Take lots of pictures as you pull 'er apart.  Ziplock baggies and markers are invaluable!
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
« Reply #4 on: August 05, 2008, 04:50:18 PM »
YEs +1, "bag em and tag em" has really helped me. I keep good quality bags handy with the slider locks so they are quick and easy to use. Also I keep index cards cut to size to drop into the bag with the description of contents. They are easier to write (use a Sharpie) on than the bag itself and that way your label will never fade or deteriorate. And you can use the bag over since it doesn't have writing on it
