Author Topic: Frame material of CB550?  (Read 1027 times)
electronbee
« on: August 12, 2008, 07:41:33 AM »
Any one know if its any special blend of steel tubing? It seems to be 18 gauge (~1mm) thick. Also, do all the bikes have the same type steel?
I plan on doing some cutting and welding and I want to buy the same type steel tubing and the appropriate wire if necessary.
eb
Offline bradweingartner
  • 74 CB 550 x2
Re: Frame material of CB550?
« Reply #1 on: August 12, 2008, 07:59:06 AM »
If I had to guess I'd say these frames are your run-of-the-mill Mild Steel. As long as you stick with a basic mild steel, 1018/A36 Something like that you'll be absolutely fine.
