Author Topic: CB550 clutch  (Read 1127 times)
Offline BARDAR
CB550 clutch
« on: August 07, 2008, 11:22:39 AM »
Are ALL CB550 clutch assemblies from 1975 to 1978 K and F models the same?  ??? I'd like to get an entire setup as a spare.  My bike is a 1977 CB550F super sport.  Thanks!
« Last Edit: August 07, 2008, 11:24:28 AM by BARDAR »
Offline bozo4onion
Re: CB550 clutch
« Reply #1 on: August 07, 2008, 12:00:53 PM »
Some sites say same. No. I bought mine for my 75' 550F from Honda. They show a different part# for the F and the..........other one. I got a Honda clutch because they designed the bike and the parts are good. Works like new. Good luck.
Offline bistromath
Re: CB550 clutch
« Reply #2 on: August 07, 2008, 01:23:34 PM »
hey uh bozo where did you end up getting a clutch assembly for your  '75 550F? did you order plates and discs as well as springs? and how much did it set you back?
'75 CB550F
ed
Re: CB550 clutch
« Reply #3 on: November 11, 2008, 06:20:05 PM »
hi ppl... the clutch on my 550f (engine says 550e!) wont spring back... ie the lever remains in and wont spring back out... any ideas on why?? Thanks.
E
Brass Brawler
Re: CB550 clutch
« Reply #4 on: November 12, 2008, 12:49:06 AM »
E
Sounds like the push rod is out of socket or the lever on the crank case has past the point of no return and slipped over the pressure plate inside... I'd open it back up, it's the only way to be certain.
ed
Re: CB550 clutch
« Reply #5 on: November 13, 2008, 04:32:53 PM »
Thanks Brass, i figured i'd have to get in there!  But wanted to be certain before i did!
