SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
Proven Tricks & Tips / How To's - NOT for Quesions
Maintenance
(Moderator:
Gordon
Topic:
CB750 Starter Removal
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: CB750 Starter Removal (Read 7731 times)
dummkauf
Enthusiast
Just got it
on:
August 09, 2008, 09:40:31 PM »
I know I've seen some threads on here explaining how you just need to work at it until you find the right angle to pull the starter out and it will just come out. Well after trying to get a good grip on it for about an hour or two and find that magical angle I finally had a brilliant idea. There is a threaded hole on the end of the starter in the center that doesn't have a bolt in it. Simply take one of the 2 bolts that you should have already removed that were holding the starter in place. Screw the bolt into this unused center hole and grab onto the bolt which will give you an excellent grip to pull the rotor up and back. The starter just slid right out when I did this so I thought I'd share with the rest of you.
Logged
jevfro
Hot Shot
1975 CB750 K5
Re: CB750 Starter Removal
Reply #1 on:
August 09, 2008, 10:09:01 PM »
very nice.
thanks for the tip!
Logged
sohcphreek
Full Member
Reply #2 on:
January 24, 2012, 12:33:57 PM »
Thanks for the tip... Did or do you have to remove the cam tensioner. im trying to avoid this if possible
Thanks sohcphreek
Logged
Bob Wessner
"Carbs Suck!"
Really Old Timer ...
Reply #3 on:
January 24, 2012, 12:41:51 PM »
This seemed like a worthwhile tip to be saved for others, so moved it here to Tips and Tricks/Maintenance. Hope you don't mind Gordon.
Logged
Bob Wessner
"Carbs Suck!"
Reply #4 on:
January 25, 2012, 06:11:46 AM »
Any tips or things to be aware of on trying to reinstall the starter motor?
Logged
Bull
Full Member
Reply #5 on:
January 29, 2012, 05:11:53 PM »
Works like a charm! Thanks for the tip.
Logged
sohcphreek
Full Member
Reply #6 on:
June 23, 2012, 11:32:38 AM »
did you have to remove cam tensioner and did the starter go back in the same way
Thanks
Logged
scottly
Global Moderator
Humboldt, AZ
Reply #7 on:
June 23, 2012, 10:01:43 PM »
Yes, you need to remove the cam chain tensioner. It probably wouldn't hurt to have to motor in the position for adjusting the chain before removing it, and to avoid turning the motor while it is removed, just to be safe.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
Maintenance
(Moderator:
Gordon
Topic:
