Well like the subject states, I have some ticking coming from my top end.
I have 300 miles on a fresh top end rebuild, and now I'm starting to get some ticking going on. I ran a search and found that it could be my exhaust flanges being loose. Went and checked it and all four were definitely loose. Torqued them all down and I still have some ticking.
Adjusted the cam chain using the 15 degrees of top dead center... Tried it again. Still ticking.
Checked the oil flow with a tappet cover off, blipped the throttle, and got oil everywhere. So I'm getting plenty of lube to the top end.
As the ride goes, I don't hear it from a cold start, only when the engine starts warming up. The ticking also increases in repetition as I increase in rpms. The ticking almost completely stops when the clutch is engaged (pulled in to switch gears). But there is always a ticking noise whether or not the rpms are increased only has to do with how loud or how more repeatious it gets..
I adjusted the tappets twice after the rebuild to make sure that they are within factory spec. But now that I have a few miles on her, does this mean that they'll have to be adjusted again?
Thanks for tuning in
![Wink ;)](http://forums.sohc4.net/Smileys/default/wink.gif)
