Author Topic: K0 gauge jewels...  (Read 1274 times)
Offline zoo mob
K0 gauge jewels...
« on: August 12, 2008, 10:51:24 PM »
Hey, I'm in a bit of a bind in regards to my gauges on my K0; the gauges on my project bike are in pretty decent shape, but the jewels seem to have fallen into the gauges a tiny bit (1/8 in. maybe) has anyone come up with a way to disassemble them and fix this problem?
Andrew
 1970 750 K0
 1980 BMW R100T
 1980 GS1100E
 1993 XR650L
Always looking for more
Offline Raul CB750K1
Re: K0 gauge jewels...
« Reply #1 on: August 13, 2008, 12:12:34 AM »
Seem too little "fall" to me. You sure it is not the way they should be? Pictures?
Offline mcpuffett
« Reply #2 on: August 13, 2008, 03:29:44 AM »
Hi theres a thread somewhere on here when Bob Wessner did his gauge faces he explains how he opened em up etc  ;), cheers Mick.
Offline void909
« Reply #3 on: August 13, 2008, 04:35:13 AM »
I recently redid my guage faces. This is the method I used. It worked great.
http://www.salocal.com/sohc/tech/speedo/spedo1.htm
knock with no answer
Offline zoo mob
« Reply #4 on: August 13, 2008, 10:32:11 AM »
Those links will be very helpful, thanks. I think they're a bit closer to 1/2" below the faces, here's a blurry pic.
Andrew
 1970 750 K0
 1980 BMW R100T
 1980 GS1100E
 1993 XR650L
Offline Johnie
« Reply #5 on: August 13, 2008, 10:58:33 AM »
Yes, 1/2" is to much.  Here are mine that I restored last winter.  Pretty close to flush with the face.  Don't be afraid to break off that black plastic ring on the bottom.  Then the unit will slide right out with some turning and pulling.  Check out that search as there is a good thread on the subject for these units.  Best of luck to you.
« Last Edit: August 13, 2008, 11:01:21 AM by Johnie »
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
