Author Topic: What and where to find the best replacement points? cb550k1 1975  (Read 1076 times)
Offline NGL_BrSH
While i'm at it i'm going to replace my points since they are oem.
for 1975 cb550k1
I've been searching a bit and see that getting a good set up points is important.. so what are good sets?  Just Nippodenso?
I seem to have a TEC plate and no idea who makes the points and the condensors.
can I use my TEC plate still without worrying that the new points are "compatible"?  I figure whatever i get will fit but figure i'll ask anyway.
« Last Edit: August 18, 2008, 10:35:18 PM by NGL_BrSH »
Offline Pinhead
  • 1979 CB652-ST
Re: What and where to find the best replacement points? cb550k1 1975
« Reply #1 on: August 18, 2008, 10:56:22 PM »
Keep your original points and get a Hondaman Ignition.
Doug
GM HEI Ignition Conversion
Quote from: TwoTired
:D
Offline NGL_BrSH
« Reply #2 on: August 19, 2008, 06:58:59 AM »
well, they are fairly pitted and i'd like a new set that are as good or better than what i have right now.
I see Hondaman's posts on here but never have seen a way to buy his stuff like a site etc...
Without bothering him is there a way to see all his products and pricing?
Offline Pinhead
  • 1979 CB652-ST
« Reply #3 on: August 19, 2008, 07:54:10 AM »
AFAIK the ignition module is all that he sells, but I'm sure a PM would clarify the issue.
The ignition module turns the points into a low voltage switch, nullifying the pitted points problem.
However, if for some reason down the road, you wanted to remove the module (transfer it to another bike maybe) than new points would be requisite. So I suppose it's down to personal preference. It's been a few years since I've had to buy points, so I don't know how much they cost now. However, I do know that when I bought them way back when for my '71 SL175 they weren't too terribly expensive. Personally, I'd find the cheapest set of new points and get a HM Ignition to go with them.
Doug
:D
Offline acteg
« Reply #4 on: August 19, 2008, 08:06:36 AM »
In the same boat as you.  My 1/4 point seems to be missing one of the contact points so there is no way I can get the gap even remotely close.  Because of this the timing is off.  I''m looking for a new set of points and so far the only places i've found are ebay and a couple of the honda websites that pop up if you google honda parts direct.
Offline Artfrombama
  • Card-carrying, board certified
  • CB750 K2
« Reply #5 on: August 19, 2008, 08:55:09 AM »
I bought a NOS breaker plate assembly off sleezebay cheaper than I could have just bought the points locally.
Found them elsewhere inexpensive.
Halfassed machinist
Tinkerer/goof-off/Mr. Fix-it
CB750-2011594 Sunrise Flake Orange
CB750E2441103
Offline NGL_BrSH
« Reply #6 on: August 19, 2008, 09:04:40 AM »
Thanks for the clarification pinhead.. that makes sense now.  I may do a hondaman ignition if i figure out where to buy hondaman parts.  Otherwise i'd like to find the best set of points i can.. which after reading soudns like the ND stuff seems to be the way to go.  If you go to hondaparts-direct I think it's a crap shoot if you get ND or TEC.
Offline Triffecpa
« Reply #7 on: August 19, 2008, 10:06:35 AM »
the best CB550 points come in a box labeled "Dyna S"
Tracy
