Author Topic: clutch lever adjustment  (Read 667 times)
bossracer
« on: August 20, 2008, 11:00:38 AM »
Ref 82 CB650SC
What is the "official" name of the fine adjustment assembly?  I'm talking about the knurled knob with the threaded hollow tube that has a slit for the cable to slide through.  My Haynes manual doesn't even show a picture of it.
Trying to find one, but don't know what to call it.
Thanks
dan
Offline Johnie
Re: clutch lever adjustment
« Reply #1 on: August 20, 2008, 11:06:38 AM »
My parts manual calls the spot the cable goes through a clutch lever.  It is shown in the clutch cover area of my parts book.  They list the threaded rod as a "shaft".  Maybe you can locate it on a parts fische.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
bossracer
« Reply #2 on: August 20, 2008, 06:03:57 PM »
thank you much for the info.  I found it.  I will order them both today!
dan
« Last Edit: August 20, 2008, 06:11:33 PM by bossracer »
