Author Topic: Lets see a photo of your SHOP!  (Read 195855 times)
Re: Lets see a photo of your SHOP!
« Reply #1900 on: June 29, 2024, 06:34:21 PM »
Kelly that news on the markers sucks! Hope your plan works well. Looks like you are trying to keep busy, hope your energy levels are back up. Praying for positive results for you. Friend has one of those...or did, not sure if he still has it.
Offline grcamna2
« Reply #1901 on: June 29, 2024, 07:06:24 PM »
Finally started to move stuff around in the garage today. No pics. Tomorrow planning on getting some more done.
Sent from my LE2127 using Tapatalk
I'm glad you finally got to work on the shop again.  8)
The Dr that did my fiducial markers missed on two of them. It pushes my final treatment back to August 22nd. So Jonesy and I are going to squeeze rides in-between appointments.
Today we pulled the 82' CB 900F carbs to fix a bad fuel tube o-ring. We finished up and fired it up, seems we need to get some bigger slow jets because of the new black ceramic Delkevik pipe. ;D
With some time left I hopped on the tractor and pulled the next project from out behind the shop.
An 03' Honda TRX 350 Rancher that my long distance riding buddy gave me. His Mom bought it new for him and he couldn't stand watching his eldest son destroy it anymore. He wants me to fix it for my son. 8)
Strong looking TRX350 Kelly.
I can't remember if you already finished the KL250 restore,how's it doing ?
Offline Kelly E
  • Geriatric Hooligan
« Reply #1902 on: June 29, 2024, 07:15:51 PM »
Waiting for the boy to get home from Iceland. Then we'll go through the ignition and get it started.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline BenelliSEI
  • 1969 cb750
« Reply #1903 on: July 31, 2024, 09:58:10 AM »
Today was super hot and humid again. Went down to the shop and cut a 18.75” X 12.5” hole through the shop wall and finally installed a small air conditioner I’ve kept aside since we moved here full time. Still have to do lots of cleanup and a few small trim bits, but it should be cooler when I go down there later! Pics then.
« Last Edit: July 31, 2024, 11:16:15 AM by BenelliSEI »
« Reply #1904 on: July 31, 2024, 11:13:39 AM »
Yeah, humidity and mosquitoes are kryptonite for me... Hate them both with a passion. That's a big reason I live in the dry desert...dry heat is so much more comfortable than humid heat. It is strange in the winter though, you either acclimated to the heat or your tolerance for the cold is severely affected... Heck, when I lived in Ohio I could sit on a tarp in the snow outside wearing some insulated Carhartt bib overalls and a old goose down coat for hours working on ta car or the like... basically sitting in the snow, coming in once every 90 minutes to 2 hours  for about 15-20 min to use restroom and get something to drink.
John,
Hope the small AC pulls enough moisture and heat from the air to make it tolerable.
Offline BenelliSEI
  • 1969 cb750
« Reply #1905 on: July 31, 2024, 11:23:27 AM »
It works a treat! Shop was below 70F when I went back down. I need to pull it out and get it draining properly out the back (dirt floor in the shed portion, so not a problem), I can hear it gurgling inside and nothing is leaking out. It’s pushing out 58F air on “low cool” and the shop was pleasant. I put the oscillating fan I use to cool engines when tuning down at the end of the shop and the whole place was lovely. Did the cleanup and called it a day!
Note the yellow colour; that unit was in my mother in law’s apartment for a few months. Guess who smoked a pack a day? Fortunately I scrubbed the filter and it doesn’t stink. Go figure? I should have done this years ago.
« Last Edit: July 31, 2024, 11:26:03 AM by BenelliSEI »
« Reply #1906 on: July 31, 2024, 02:40:05 PM »
Lots of white plastics will oxidize age into yellow cast like that, doesn't necessarily reflect being in smoking environments. Apples & old CRT monitors have this issue and lots of refrigerator handled have that issue too. Hydrogen peroxide treatments with strong hydrogen peroxide solution can bleach them white again...
Glad the AC unit is doing the job, definitely want to get it pitched correctly to keep it from developing mildew issues...
Offline BenelliSEI
  • 1969 cb750
« Reply #1907 on: July 31, 2024, 02:56:46 PM »
Yes. I need to install a “crosser” under it in the wall and repair the vapour barrier. Will pull it out tomorrow and pull the cover. Full clean out and inspection, lube etc. It has no drains, so I suspect it’s suppose to blow dry itself. That will get modified…..
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #1908 on: July 31, 2024, 03:37:46 PM »
Looks great to me! Sheeesh, i may as well take over your shop
Offline BenelliSEI
  • 1969 cb750
« Reply #1909 on: July 31, 2024, 04:32:06 PM »
Anytime!
I finished up by framing the interior of the “hole” with 2” X 8” lumber. Repaired the vapour barrier and insulation, packed around the opening. Removed all the covers on the AC unit and gave a good cleaning. The back end of the undertray had no drain holes. I’m guessing the condenser fan is suppose to pull air across and help it evaporate? Drilled 1/2” holes in both back corners. It hangs out into the barn (gravel floor) so drainage is no issue. Added a strip of lumber across the inside framing and a few screws to stop the “rattles”. On “Low Cool” it’s pushing out 55F air and the shop is just perfect. I may move in!
« Last Edit: August 02, 2024, 06:49:30 AM by BenelliSEI »
« Reply #1910 on: August 19, 2024, 09:10:41 PM »
 I needed some space so I put a pair of frames on the shelf and decided to put the turbo drag bike up there too. I have a k2 with stuck valves and my Rat Race that both need engine work before the drag bike gets a turn.
 That frame has been raked a few degrees and the under-tank tubes are arched up like a 750A except the K tank still fits. The rocker cover can come off in the frame.
« Last Edit: August 20, 2024, 09:10:09 AM by Don R »
Offline BenelliSEI
  • 1969 cb750
« Reply #1911 on: August 20, 2024, 04:53:16 PM »
Don….. Got to ask: How do you get them up there?
« Reply #1912 on: August 20, 2024, 07:17:33 PM »
 I have a deep channel unistrut attached to the ceiling with another unistrut in the attic over the trusses attached with carriage bolts. They make a thousand lb. load trolley that fits into the strut and I have a half ton chain fall on that.
 I don't have engines on them but they roll on the shelf once they are up there.
Offline BenelliSEI
  • 1969 cb750
« Reply #1913 on: August 21, 2024, 04:45:23 AM »
Great space utilization!
Offline BenelliSEI
  • 1969 cb750
« Reply #1914 on: November 15, 2024, 05:09:15 PM »
Shop photos are my favorite. Why has this section dried up……
Today I replaced another stretch of fluorescent lighting in my shop. Two X eight foot fixture, each one had two (double pin) 4’ lamps. Pulled the ballasts and hard wired 120V directly to the ends and installed the 4’ LED’s. Fairly easy job, see instructions attached.
Wow. Forgot to take a picture, but the “working end” of my shop is now done. My old tubes were ancient, so had lost much of their strength. It seems 2X brighter now! Will take some snaps next time……
« Last Edit: November 15, 2024, 05:14:04 PM by BenelliSEI »
« Reply #1915 on: November 16, 2024, 09:53:31 PM »
 My old buddy Tom's drag bike on the shelf. He said NHRA asked him if he was willing to tear down for a national record. He declined. Reportedly, he roller started it with a set of grocery store conveyer rollers and his van to turn it.
« Last Edit: November 16, 2024, 09:56:31 PM by Don R »
« Reply #1916 on: November 16, 2024, 09:58:01 PM »
 My sign and banner collection.
« Last Edit: November 16, 2024, 10:28:32 PM by Don R »
« Reply #1917 on: November 16, 2024, 10:02:12 PM »
 Sacrifices to the Gods of Speed
  The main cap is broken into 3 pieces out of our 383 small block chevy it went 7.92 on spray 8.03 natural at 172 mph. It never let go it just slowed a couple tenths.
  The Briggs  and Stratton let go on friday night of the World Series of Drag Racing.
  We were in the final and made the first pass after the national anthem on Friday night at the big show.
  Maybe in front of 20-30,000 people and the first passes under the new Musco lighting. My daughter left second and already caught the other car when the hard as glass stock briggs crankcase let go sending sparkles into the air.
  The cylinder stuck on the piston but the rod and crank held, the top of the engine was thrashing back and forth. The header went through the deflector plate but just cut a C in it. All of the pros signed it the next day, most of them were watching because they hadn't seen Jr. Dragsters before.
« Last Edit: November 16, 2024, 10:13:58 PM by Don R »
« Reply #1918 on: November 16, 2024, 10:21:44 PM »
 In the above pic, the rectangle is the burst panel out of a Top Alcohol dragster. It used too much fuel on the pit warm-up but no one listened to me. The main jet in the barrel valve had fallen through and blocked the return. The car went lean at 1,000' and popped the blower off.
 Upper left is a barely used moroso billet oil pump from out 567" big block, the Crane roller lifters spit out needles and they fit perfectly through the screen on the pick-up, the jagged timing chain also ate some needles. The gears are from the next time when the roller lifters took a poo. We were able to save the body that time.
  The holy piston is out of Tom Hoovers Funnycar, the rod and piston were from Tim Wilkersons Funnycar.
« Last Edit: November 16, 2024, 10:24:05 PM by Don R »
Offline Gurp
  • I'm no.......
  • Once was a...
« Reply #1919 on: November 16, 2024, 10:47:49 PM »
Don, I'm hoping soon I can start posting pics of progress in my garage to this thread but for now I'm stalled on everything with the house/garage.
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
Future project 77 Cb750 Amen Savior
Offline grcamna2
« Reply #1920 on: November 17, 2024, 12:08:08 AM »
Nice sign and banner collection Don.
Offline BenelliSEI
  • 1969 cb750
« Reply #1921 on: November 17, 2024, 05:27:28 AM »
Don….. love the expensive “Shrapnel” collection. I used to have one myself, but a few years ago I did a scrap run and threw it all in. Still regret that brain fart!
« Reply #1922 on: November 18, 2024, 10:36:00 AM »
I sold my old Logan, made some space in the shop.
It got bought by company that tests roads and runways; I never knew it's a thing.  The guy who came to pick it up was from France, moved to USA in 1964 after he finished military service in Algeria, now he makes living as machinist and must be pushing 80 if he is a year.
But the shop space will not be empty long, we got a new frame for my CJ7 and my son will be building it frame up over the winter.
Offline grcamna2
« Reply #1923 on: December 08, 2024, 12:18:36 AM »
 8) :)
Offline newday777
« Reply #1924 on: December 08, 2024, 12:50:53 PM »
Is your shop there in open air where you had your Logan?
Stu
My current rides
Prior bikes....
