Author Topic: Igniters melted on CB650C  (Read 1116 times)
iwasaseabee
« on: August 24, 2008, 08:12:41 AM »
What causes the epoxy on the inside of the coil amplifiers to melt on a 81 650?
Re: Igniters melted on CB650C
« Reply #1 on: August 24, 2008, 08:19:21 AM »
Age, use etc. It's very common on the DOHC Honda's from the early/mid 80's
« Reply #2 on: August 24, 2008, 08:26:15 AM »
The electrolytic capacitors inside fail with low resistance (if not a direct short).  This causes high current to be drawn which is converted to heat, high enough to melt the plastic.
....or so I've heard.
Offline tonycb650
« Reply #3 on: August 24, 2008, 08:38:47 AM »
Mine are also melted on my 650.It seems to run fine. Is this a problem? should i change them? Would it run any better? will this leave me on the side of the road some day?
80cb650c 80 cm400
Offline mystic_1
  • 1970 CB750K
« Reply #4 on: August 24, 2008, 09:32:52 AM »
Yes.  Yes.  Maybe. Probably.
mystic_1
- John Augustus Shedd
« Reply #5 on: August 24, 2008, 09:53:30 AM »
I'm trying to imagine seeing an electrical component that was melted and thinking it was a good thing and inspiring confidence toward reliability.   ???
Don't think I'd go on long trips under such conditions.  But, I'm just not as adventurous as I used to be.
Offline tonycb650
« Reply #6 on: August 24, 2008, 10:08:29 AM »
thanks alot tt and mystic! >:( now i have something else to fix. :(
80cb650c 80 cm400
KingCustomCycles.com
« Reply #7 on: August 24, 2008, 10:10:36 AM »
I have an 80 CB650C with melted ignitor boxes.  The epoxy goop ran down onto the airbox and never did get hard again, just sticky.  I thought it was from a PO catching the bike on fire, which he obviously did, but now I wonder.  I spark tested the bike and she has good spark.  On the other hand, my Shadow had pulse generators that appeared perfect and tested fine, yet no spark.  Go figure.
« Reply #8 on: August 24, 2008, 10:14:55 AM »
Hey, you don't have to listen to me.  I've never had a 650 SOHC4!   ;)
I did work in electronics for 30 years. ::)
Offline tonycb650
« Reply #9 on: August 24, 2008, 10:29:51 AM »
 I actually figued i needed to replace them, i guess i didnt want to hear it. ;D anyway , i will trust yours and mystics judgement over mine any day! ;D
80cb650c 80 cm400
martino1972
« Reply #10 on: August 24, 2008, 11:13:27 AM »
are we talking about the cdi unit?????
Offline tonycb650
« Reply #11 on: August 24, 2008, 11:48:42 AM »
the part im refering to is called the spark unit. its located under the seat.it actually looks like 2 pieces.
80cb650c 80 cm400
Offline cb650
« Reply #12 on: August 24, 2008, 01:37:41 PM »
I carry a extra set of these with me.
