SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Clutch Splined Washer
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Clutch Splined Washer (Read 3783 times)
CB750F2
Hot Shot
Pat's first Honda 750 F2
on:
April 13, 2005, 12:40:59 AM »
G/Day everyone. I have disassembled the clutch on my 78 F2 to ensure that I had assembled it correctly during my recent restoration. Gear selection has been notchy so I am trying to improve this. The only thing that I can find is that the splined washer - part no. 90432-392-000 - that fits between the clutch centre and a shoulder on the main transmission shaft looks to be worn in the splined area of the washer. The splined area on both sides is bevelled inwards and so does not provide a nice square face to the shoulder on the main shaft. Can someone tell me if a new one is like this and what thickness the washer is. Mine is 3mm thick but reduces to approx. 2mm on the inner edge of the splines. I am trying to purchase a new one from Honda but I suspect that these washers are no longer available. Thanks, Pat from Nth Qld Aust.
Logged
Regards
Pat from Australia
cben750f0
nothin draws attention like a classic bike!!
Master
'75 CB750F0 Gladstone NQLD OZ
Re: Clutch Splined Washer
Reply #1 on:
April 13, 2005, 07:17:00 AM »
mate those washers are ment to be a neat slide fit on that shaft.... when i piked my bike up...... i could never get it out of gear... it had a new clutch.... thought to myself... might jst check that..... the dumb ass i bought the bike off..... LEFT IT OUT!!!... so basically he had bolted my inner clutch cage to my outer clutch cage... needles to say this dont make for easy shifting.... the allot was the only bearing sureface i had...... new washer.... different bike..... so in conlusion... get a new washer... and you will be a happy man... peace
Logged
he said \\\\\\\'it was like watching a 250kg unguided weapon getting stuck up you bum\\\\\\\
http://www.bikepics.com/members/trixtrem/
CB750F2
Hot Shot
Reply #2 on:
April 13, 2005, 11:36:06 PM »
Thanks for the feedback. Did you purchase the washer from Honda? I have one on order but there is nil stock in Australia. I will know Monday or Tuesday if it can be supplied from overseas. Can you remember if the faces of the washer are nice and square?
Peace, Pat from Nth Qld
Logged
Regards
Pat from Australia
cben750f0
Master
Reply #3 on:
April 14, 2005, 12:59:37 AM »
na got mine off my mechanic... if he dont have it for a 750/4 then it aint worth haveing....give me your address and i will try to get one and send it to you express... goto be cheaper than buying it... cheers..
Logged
CB750F2
Hot Shot
Reply #4 on:
April 14, 2005, 02:28:35 PM »
Thanks for that. It would be great if you could get hold of one for me. Can you send it COD to Patrick Larsen 39A Chippendale St Ayr 4807? Thanks, I hope that I can help you one day. Pat
Logged
Regards
Pat from Australia
cben750f0
Master
Reply #5 on:
April 14, 2005, 02:30:34 PM »
will get on it today... cheers....peace
Logged
cben750f0
Master
Reply #6 on:
April 14, 2005, 09:16:39 PM »
g'day pat,
just want to clarify if this is the washer you are after... also its gonna cost you a forture.... how bout free?... will send it monday... peace
Logged
CB750F2
Hot Shot
Reply #7 on:
April 16, 2005, 03:15:02 AM »
OK I see the picture. The OD is bigger than mine but that should not be a problem so send it up. The condition of the washer in the splined area is much better than mine. Thanks and er peace. Pat
Logged
Regards
Pat from Australia
CB750F2
Hot Shot
Reply #8 on:
April 16, 2005, 03:44:29 AM »
PS I will put up another reply when it arrives. If you are interested my web site address is:
http://users.tpg.com.au/patrickl/patsbikerestoration.htm
. My email address is there. The site shows a few photos of the resoration of my F2. Thanks again, Pat
Last Edit: April 16, 2005, 09:33:32 AM by SteveD CB500F
Logged
Regards
Pat from Australia
bwaller
Really Old Timer ...
Reply #9 on:
April 16, 2005, 04:43:49 AM »
Hey Pat,
I'm a little late joining the fray, but I have 10 NOS washers part #90432-300-303. If you don't have any luck with the other source, you can check to see if my old number has been superseded and if so I have one available.
Brent
Logged
CB750F2
Hot Shot
Reply #10 on:
April 17, 2005, 03:21:09 AM »
Brent. Thanks for your input. The centre bit of the part number for my washer is 392 the OD is ??mm and the thickness is 3mm. I suspect that the OD for the earlier models is larger but I am unsure of the thickness. The larger OD is not a problem but the thickness must be 3mm. As you can see by the other replies I have one coming from another Australian member. If on the off chance that the one I receive is not suitable I will contact you via email - I can see your email address in your profile. Thanks for the offer. Pat from Nth Qld Australia.
Logged
Regards
Pat from Australia
CB750F2
Hot Shot
Reply #11 on:
April 17, 2005, 03:25:35 AM »
Brent. I forgot to tell you that the OD is approx. 32mm. Sorry, Pat
Logged
Regards
Pat from Australia
cben750f0
Master
Reply #12 on:
April 17, 2005, 05:12:18 AM »
talking to my mechanic, he says that the centres are the same the thikness is the same ... its the od'd that are different... will post the washer tomorrow... will send it express.... hope it works... BTW if you are after anything else let me know.... PM if so... peace
Logged
cben750f0
Master
Reply #13 on:
April 17, 2005, 07:53:40 PM »
F2 sent the washer today... should be there by thursday friday... cheers
Logged
CB750F2
Hot Shot
Reply #14 on:
April 21, 2005, 03:31:39 AM »
G/Day Ben. I received your washer today - many thanks. It is in much better condition than mine. I will probably have to machine the OD down to approx 32mm but that will be no problem. Thanks, Pat from Nth Qld.
Logged
Regards
Pat from Australia
cben750f0
Master
Reply #15 on:
April 21, 2005, 07:53:55 AM »
its all good mate... NE time...peace
Logged
CB750F2
Hot Shot
Reply #16 on:
April 26, 2005, 04:55:01 AM »
I received the washer, machined the OD down to 32mm, reinstalled the clutch with new friction plates. Clutch operation is much improved - I would say "normal". Thanks for your support. Pat from Nth Qld
Logged
Regards
Pat from Australia
cben750f0
Master
Reply #17 on:
April 27, 2005, 01:03:05 AM »
cheers mate glad i could get you back on tha road..peace
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
