I'm thinking you (or someone) adjusted them wrong.
Each float valve has a small spring pin at the end which rests on a tab which is part of the float pivot.
I'm guessing that someone adjusted the float height with that pin fully compressed, which is wrong.
That small pin on the valve should be fully extended and the valve on the seat when the tab makes contact and the height is measured.
The tab is then bent to achieve this orientation at the measured float hight.
The problem with this theory is that this error should have the fuel level too low.
Or...
Did you remove the float seats from the carb bodies? They seal with orings. Did you replace these? Could they be damaged and allowing fuel to bypass the float needles?
Or...
Have the float needles been put in backwards?
I'm guessing you've got some kind of assembly error, that you can't see as obvious, since you got them that way. Especially since all four are behaving the same way.
The float system is a fairly simple mechanism, that, with some thought and observance, can be easy to understand the principles of operation.
There's a fuel supply on the inlet of the valve. When the fuel level rises, so does the float and it closes the valve, stopping fuel entry. When the fuel level falls, the valve opens again to let fuel in. (Your toilet cistern has the same type of fill principle, btw.)
Take it apart, observe, adjust, and make it work like it should.
Or, take some pictures so we can see WTF.
