Author Topic: Crankcase corrosion  (Read 1481 times)
velo13533
Crankcase corrosion
« on: September 11, 2005, 01:40:48 AM »
Ive just inherited dads CB 750,that must have stood out in the open a lot as the forks and all the alluminium on the crankcases looks corroded.Any suggestions for restoring the ally to its polished state?
bike54
Re: Crankcase corrosion
« Reply #1 on: September 11, 2005, 02:28:22 AM »
hi velo13533
try fine wire wool and wd 40 followed by a good chrome cleaner long job but the end result is worth it
merv  :)
Offline frostypuck
« Reply #2 on: September 11, 2005, 04:44:57 AM »
I put a small buffing pad on my power drill, using the black buffing compound first, you can get right thru the corrosion and the yellow coating under that. Once the metal begins to shine like chrome, switch to brown compound and then finish up with white. Maybe 45 minutes to do all the case covers, if they are on the bike.
Good luck,
Chris in Boston
Boston, MA, USA
