Hi all,
I just bought a '78 CB750K yesterday. Rode it home 85 miles fine, but it has issues. First and foremost is that the kid I bought it from had the carbs 'rebuilt' recently. I noticed the carb closest to my right food leaks from the bowl because the gasket got swollen and now there's a gap. I figure I'll take the bowl off, and try to get it back on. I'm not sure if this is related, but the bike is almost impossible to cold start, especially if it's been sitting for more than 8 hours up to a few days. It starts right up no problem once the engine is warm, even with the kick start. But once it's cold, it just turns over endlessly, sounding as though it wants to catch but just wont go. You can smell gas pretty bad when trying to start it like this too. If you pump the throttle a few times while trying to start it, it makes even more promising "want to catch" sounds but still wont go.
Once it's started, it sounds like the transmission is full of marbles. It rattles pretty bad, less so if the clutch is in, but still audible. You can't hear it up past, say, 2500 RPM. The gears also whine when accelerating and they make a very loud CLUNK when you shift them in. I've also noticed that the bike surges a bit when you engage the gears, especially the low end, almost as if the clutch wasn't fully engaged. What's all that about? I've read there is a common "clutch rattle" but this sounds worse than other descriptions I've read. Perhaps the carbs are so out of sync it sounds worse (the engine vibrates way more than other 750's I've seen at low idle).
So that's where I'm at. The bike has 19k on the odo, is in otherwise gorgeous shape for a 30-year-old bike and the engine pulls really strong even with the carbs being obviously out of sync pretty bad (or at least that's my assumption).
