Author Topic: CB750 K0 throttle friction spring  (Read 1504 times)
kaysystems
« on: August 31, 2008, 04:45:58 PM »
Inside the twistgrip of the CB750 K0 is a spring device intended to stop the throttle closing when let go. There is a screw underneath to press n the sring plate.
How is the spring held in place? Is there supposed to be a hole in it for the screw to go in?
Mine keeps moving out of place.
thanks
David
Re: CB750 K0 throttle friction spring
« Reply #1 on: August 31, 2008, 05:44:40 PM »
thanks
David
Does the original micro fiche show the set up? How is that old bird running David.....I think about her from time to time. ;)
kaysystems
« Reply #2 on: August 31, 2008, 06:06:52 PM »
The micro fiche isn't too clear, but I think there's a hole in the spring.
She's runnin' fine...I do believe that 100mph all day claim is feasible..No oil leaks, just a few strange noises now & then. But she really wants to go.
David
« Reply #3 on: August 31, 2008, 07:16:11 PM »
David
I make a few strange noises now and then too David. Good to hear she's running well with no oil burning. ;)
Offline Johnie
« Reply #4 on: August 31, 2008, 07:58:54 PM »
I checked with my dealer and the parts numbers are no longer around.  I believe you would tighten the screw and it would tighten a rubbing block on the underside of the throttle sleeve.  It would sort of take some of the tension off the spring so it was not so hard to hold speed.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Artfrombama
  • Card-carrying, board certified
  • CB750 K2
« Reply #5 on: August 31, 2008, 11:42:34 PM »
Which brings me to another newb question;
Why is the throttle spring so darned stiff? (CB750K2)
Halfassed machinist
Tinkerer/goof-off/Mr. Fix-it
CB750-2011594 Sunrise Flake Orange
CB750E2441103
kaysystems
« Reply #6 on: September 01, 2008, 05:19:35 AM »
David
And no oil leaks around the valve cover....
