Author Topic: This Nullifies My Air Filter. And it makes me sad.  (Read 2332 times)
Offline OakBehringer
« on: September 01, 2008, 11:13:51 AM »
Two items in question:
1) The metal tube that extends out of the air filter box, towards the engine.
2) The plastic box that the carbs connect to.
It seems like item (1) should extend all the way into item (2) and probably have some sort of gasket around it. Mine does not, as you can see in the pictures. The gap is actually a bit larger than it looks. There's no way all of my air is getting safely filtered. Can somebody clarify for me how this SHOULD be?
Thanks!
« Last Edit: September 01, 2008, 11:43:44 AM by OakBehringer »
1974 350 Four - SOLD
1966 CL160
1981 XS650
1972 CT70
Finished CB350F
HELLS BANANAS
Offline mark
Re: This Nullifies My Air Filter. And it makes me sad.
« Reply #1 on: September 01, 2008, 12:20:39 PM »
What bike?
F you mark...... F you.
Offline kghost
« Reply #2 on: September 01, 2008, 12:22:51 PM »
Looks like a 350 or 400.
There should be a rubber piece there.
Stranger in a strange land
Offline hoodellyhoo
  • CB350F
« Reply #3 on: September 01, 2008, 02:36:11 PM »
Just went out to double check on my 350. Deffinitely missing the rubber piece.
« Reply #4 on: September 01, 2008, 04:07:34 PM »
Yup - 350 (says so in my signature). Anyone know what that rubber piece might be called so I can order one?
Thanks,
Adam
1966 CL160
1981 XS650
1972 CT70
Finished CB350F
HELLS BANANAS
Offline WFO
  • Will work for powerbands
« Reply #5 on: September 01, 2008, 04:20:18 PM »
17236-333-000
http://www.ehlerdingmotorsports.com/fiche_section_detail.asp?category=Motorcycles&make=Honda&year=1974&fveh=2901
If they have it i don't know it looks like #6 is your missing seal
82 cb650 sc nighthawk - 78 kz 650 b
« Reply #6 on: September 01, 2008, 04:27:26 PM »
Do you have a #3 that pushes the filter forward?
Offline mark
« Reply #7 on: September 01, 2008, 04:28:24 PM »
It looks more like the rubber seal that is part of the airbox (#15)is gone - along with clamp #13.
Offline WFO
« Reply #8 on: September 01, 2008, 04:36:34 PM »
Ya after looking at it further looks like a different seal but it doesn't show it.
Offline WFO
« Reply #9 on: September 01, 2008, 04:54:17 PM »
You think it should be pushed in further TT? iam kinda learning towards that since the detail doesn't show anything there.
« Reply #10 on: September 01, 2008, 05:00:15 PM »
I've not seen a 350 Four in that detail.  But, I would look to see what stops it from moving that cone of rubber towards the seal.
Hey, It's free advise and worth every penny!
« Reply #11 on: September 01, 2008, 05:36:56 PM »
What. The heck.
I just went out and pulled some parts off. Attached are more pictures.
#5 & #6 are definitely on there. #13 is not, but I have no idea why it would be, because I don't see what it would join #5 to.
Anyone out there with a 350f able to see what they have?
Thanks,
Adam
btw I do have #3, but even if I didn't it wouldn't matter. All of this is part of the air box, the filter simply sits inside it.
1966 CL160
1981 XS650
1972 CT70
Finished CB350F
HELLS BANANAS
Offline mark
« Reply #12 on: September 01, 2008, 11:20:43 PM »
I think it should look more like this:
Offline gregk
« Reply #13 on: September 02, 2008, 07:22:22 AM »
The # 3 in the diagram forces the filter to seat against the front of the airbox.  You definitely need this part.
Greg
I don't want it to go like a motorcycle, I want it to go like a rocket!
Offline heffay
« Reply #14 on: September 02, 2008, 07:37:29 AM »
i believe your part is actually part of the intake manifold... the 1 into 4 part.  since i don't see the part on the fiche, that is my guess.
fairly fragile part and they end up glued back together or just plain missing over time.  good luck.
p.s... thanks for making me check my filter... looks dirty and in need of replacement.   ;)
Offline heffay
« Reply #15 on: September 02, 2008, 07:39:42 AM »
#3 is a simple spring
#13 is the hose clamp for your missing part
« Reply #16 on: September 02, 2008, 07:56:46 AM »
Yup, that's it. Mystery solved. You can see it in Mark's picture, compared to the picture of my 4-1 box. I think you can even make out glue reside in my picture :)
So that part isn't removable? It's supposed to be permanently connected to the 4-1?
1966 CL160
1981 XS650
1972 CT70
Finished CB350F
HELLS BANANAS
Offline 333
  • Time for change
« Reply #17 on: September 02, 2008, 08:50:45 AM »
As a former parts guy, I can tell you that the part in question is definitely not on the fiche pic.  I don't mean to state the obvious, but it is a little busy in that pic.  And it wouldn't be on another page either.  My guess is that it's not available separately.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline WFO
« Reply #18 on: September 02, 2008, 11:05:26 AM »
Looks like if you get another #6 turn it around and clamped on would fix the problem.
Offline kghost
« Reply #19 on: September 02, 2008, 02:56:50 PM »
Won't work. Holes different
Offline cb350f-mark
« Reply #20 on: September 03, 2008, 06:57:47 PM »
« Reply #21 on: September 04, 2008, 06:19:40 PM »
As I was browsing ebay for parts tonight I saw the following item and though of this thread.
 http://cgi.ebay.com/ebaymotors/Honda-CB350F-Air-Box-Filter-Very-Good-Condition_W0QQcmdZViewItemQQcategoryZ35597QQihZ025QQitemZ380060202279QQrdZ1QQsspagenameZWDVW
Whoa! Thanks, but I already ordered a replacement from someone on this thread.
1966 CL160
1981 XS650
1972 CT70
Finished CB350F
HELLS BANANAS
