Author Topic: Will JB Weld work?  (Read 5510 times)
Offline scondon
  • Mmmm......tasty bugs
Will JB Weld work?
« on: September 02, 2008, 10:26:41 AM »
 Anytime I get a wide open straight road with no traffic or intersections I've been whining the Sumbich up for some speed runs. No problems for 19,023 miles, but on this particular stretch of road outside of Williams,CA something kicked up and knocked a small hole in my case. I'm thinking a bit of JB Weld oughta do the trick but figured I would ask here first. Whaddya think?
 :D :D :D :D :D :D :D
Offline ColinMc
  • There aint no pickle like a super pickle...
Re: Will JB Weld work?
« Reply #1 on: September 02, 2008, 10:44:47 AM »
Duct tape and a piece of gutter tin should have you back on the road in no time...don't bother with that JB Weld crap.
1976 CB750K - Cafe Project...taking forever
1984 Honda MB-5 - MB-8 conversion in process
2001 Ducati 748 - Built 996 motor sleeper
cdwicks
« Reply #2 on: September 02, 2008, 10:49:45 AM »
I agree with the previous reply.  JB is great on some things, but not things that deal with fossil feuls.  I wouldn't bother with it.  I have tried to use it on carbs and the gas eats it right up.  Just my opinion....
cdwicks
« Reply #3 on: September 02, 2008, 11:08:14 AM »
I've heard of total loss ignition systems but total loss oil systems are a brave new frontier Sean
Offline WFO
  • Will work for powerbands
« Reply #4 on: September 02, 2008, 11:12:46 AM »
heck ya it works i had a 93 beta synt they had plastic gas tanks anyways it mounted on the back by screws and had lossened up and wore a hole into the tank so i gobbered up the intire area sanded it back into shape and redrilled the hole ( good as new) and it isn't effected by gas and i was using 105 racing fuel mixed 70 to 1 but i don't know about that application seems the bonding would be in question you would really have to prep the area good.
« Last Edit: September 02, 2008, 11:16:45 AM by WFO »
82 cb650 sc nighthawk - 78 kz 650 b
Offline ColinMc
« Reply #5 on: September 02, 2008, 11:18:41 AM »
I think he was going for a cheap way to get that ducati dry clutch noise...
EDIT: I was actually joking before...ive' used JB weld on stuff before with good results as far as a cob job goes...crank cases, fuel tanks...Seal All seems to work better on gas stuff though.
« Last Edit: September 02, 2008, 11:26:51 AM by ColinMc »
Offline scondon
« Reply #6 on: September 02, 2008, 11:39:51 AM »
   When that stuff hit my collector the plume was visible from space :D
Offline Sporkfly
  • The frosty rider
  • Mmm, Guinness
« Reply #7 on: September 02, 2008, 11:40:15 AM »
Why you have your rod just hanging out there?  :-\
1977 CB550K
1979 CX500
1976 Suzuki GT500 Titan
« Reply #8 on: September 02, 2008, 11:42:56 AM »
Very straigfoward fix.
Shove that connecting rod back in.
Stiff some screening in the hole.
Apply the JB Weld, let it cure and sand.
Kawasaki had some nice running bikes with 3 cylinders.  ;D ;D ;D
Offline scondon
« Reply #9 on: September 02, 2008, 11:44:05 AM »
    It's hanging out 'cause it's lazy, shiftless, and good for nothin' ;)
Offline scondon
« Reply #10 on: September 02, 2008, 11:47:15 AM »
   I was thinking of yanking the piston and rod through the hole. I've run on 3 for many a mile and may just use this for the commute. Will this affect my crankcase pressure? thinking of sticking a one-way valve in the center of the JB patch job ;D
KingCustomCycles.com
« Reply #11 on: September 02, 2008, 11:54:57 AM »
I hate to get all technical and s**t at this point but the bond to the metal will be enhanced with a bath in MEK, acetone, or Lacquer thinner.  It isen't the JB I would worry about failing as much as the substrate bond. ::)  Paint the little dobble to match and rock on!
If ya coat that there JB Weld with Kreem tank sealer it will reattach a broken float support post that has been drilled and pinned also and save unstacking the rack.
« Last Edit: September 02, 2008, 11:58:40 AM by KingCustomCycles.com »
Offline kghost
« Reply #12 on: September 02, 2008, 12:03:51 PM »
Going for the Triumph Trident sound huh?
Ya poser  ;D
Stranger in a strange land
Offline scondon
« Reply #13 on: September 02, 2008, 12:21:03 PM »
Ya poser  ;D
    It DOES have the generous brit bike oil leak going for it now. A bit of paint and.......hmmmmmm. I think your on to something!  ;D
Offline ev0lve
« Reply #14 on: September 02, 2008, 12:22:09 PM »
Holy smokes! I'm going to have to fly my noob flag here. I mean, I've used JB on cracked alternator covers and the like but that was just a seam. This though...? You guys are joking here and I'm just not getting it right? Would JB actually be effective on that big a hole even with something like a mesh to let hold it's shape?
« Reply #15 on: September 02, 2008, 12:27:35 PM »
If that's what you call a small hole....OH never mind, It's an American small hole ;D ;D ;D ;D ;D ;D ;D
Sam and Chris ;)
« Reply #16 on: September 02, 2008, 12:29:08 PM »
Yes, the picture shows a rod failure and the post is regarding a rock chip.  Unless I missed the boat also?  It has happened a time or two.
Offline WFO
« Reply #17 on: September 02, 2008, 12:50:31 PM »
Yep the rock thing had me confused as well that section was clearly knocked ( out ) not in.
Offline scondon
« Reply #18 on: September 02, 2008, 01:07:59 PM »
 Definite "tongue in cheek" first post gentlemen :)  I've seen pics of rods kicking holes in cases before but this is my first time having it happen to me. The amount of aluminum that was kicked out of both upper and lower cases was so "over the top" compared to what I had seen previously that I didn't bother to make it clear as to what had happened. It was a SPECTACULAR FAILURE!!!!! ;D ;D ;D ;D
Offline Johnie
« Reply #19 on: September 02, 2008, 01:10:45 PM »
Yah, you had me going too.  I thought, "crap, what the heck is he talking about, stone???"  At first I thought it was Harley art... ;D
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline scondon
« Reply #20 on: September 02, 2008, 01:16:21 PM »
The "something kicked up and knocked a small hole in my case" was my rod kicking over the crankshaft on its way to freedom from the confining cases ;) ;D
Offline Brantley
  • Drano
« Reply #21 on: September 02, 2008, 01:43:16 PM »
You don't keep a piece of chewing gum in yr bike's tool kit? ::)
« Last Edit: September 02, 2008, 01:46:36 PM by Brantley »
« Reply #22 on: September 02, 2008, 01:54:52 PM »
I'll bet you were screwing it's bollocks off, how many times do you have to be told....theres no power after 9,000 ::) ::) ::) ::) ::) ::)
Sam.
Offline kghost
« Reply #23 on: September 02, 2008, 02:00:46 PM »
Sam.
Yeah well...ya have to check...might be hiding there.
Offline mystic_1
  • 1970 CB750K
« Reply #24 on: September 02, 2008, 02:01:17 PM »
Well at least the conrod cap made it out to spread the word about the unfair labor practices you make them work under ;)  Just wait, your output shaft components will be the next to revolt.
mystic_1
- John Augustus Shedd
