Author Topic: Steering Stem Question  (Read 1468 times)
Offline KB02
« on: September 05, 2008, 08:59:57 AM »
So as I start working on a Front end swap on My 750 K8, I have come across this question: Is the steering stem welded into the lower Tripple tree? I thought that I had read somewhere they were all pressed in, but mine appears to have been welded in.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline Triffecpa
Re: Steering Stem Question
« Reply #1 on: September 05, 2008, 09:05:24 AM »
most of the Honda lower triple clamps are steel and the stem is welded into it.  However, your can grind the weld off and press the stem back out and it can be used again.
Offline KB02
« Reply #2 on: September 05, 2008, 09:17:58 AM »
Okay. That's what I was thinking I might have to do.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Offline Triffecpa
« Reply #3 on: September 05, 2008, 09:23:20 AM »
if you are going to use the Honda stem in an aluminum lower triple clamp, you will have to find a method of attaching the steel stem to the allow clamp.  Most alloy clamps use steel stems, but they have a "hat" on the bottom of the stem that keeps them from pulling up thru the clamp.  Your options are to weld a nut inside of the Honda stem and then use a bolt with a big washer to hold the stem from pulling up thru the clamp, or drilling thru the clamp and the stem and "pinning" the stem in place.
Tracy
Offline KB02
« Reply #4 on: September 05, 2008, 10:34:40 AM »
My new lower TT is steel. So I should be all set.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
« Reply #5 on: September 05, 2008, 11:58:37 AM »
About your avatar...who peed into your cylinders?  :o
That's about how the Hondaman Special looked when I tore it down. I had to drive the #4 piston-rod combo out with a sledge hammer and pipe by splitting the cases and unbolting the rod, AFTER 6 weeks of soaking in every kind of release agent I could get. The cylinders are now a candidate for a big-bore kit, like 811 or 836cc, because the pitting was so deep.
Offline KB02
« Reply #6 on: September 05, 2008, 06:44:39 PM »
Sounds about the same as what I went through.  ;D  Bored out to 849 now.  ;)
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
« Reply #7 on: September 06, 2008, 07:40:29 AM »
849cc, eh? I haven't heard of that one before. Is it like an oversize repair kit for the 836cc?
Offline KB02
« Reply #8 on: September 06, 2008, 02:41:20 PM »
It's the Cycle-X 850 kit. Ken (at Cycle-X) says it's actually 849. But, yeah, you can bore out an 836 to 850. At least that's what they advertise on their website.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
