Author Topic: I had a dumb idea  (Read 1298 times)
Offline MJL
  • Don't listen to me, I'm no
I had a dumb idea
« on: September 06, 2008, 07:24:27 AM »
Propane conversion...
Maybe replace the gas tank with a pair of 1 or 1.5 gallon propane tanks, replace the carbs with a pair of propane carbs on  cyclex manifolds, just thinking..
I wonder how far 2 gallons of propane would go.  A barbeque tank would be great as I could get one ant most any gas station and many hardware stores, but it would be hard to package on a bike.  (Like saddlebags, one on each side? ;D )
Maybe not such a great idea.
Offline PJ
Re: I had a dumb idea
« Reply #1 on: September 06, 2008, 07:26:46 AM »
I had an idea like that but with CNG. Compressed natural gas is a real option if you don't mind 3600psi between the jewels. :o
« Reply #2 on: September 06, 2008, 07:43:48 AM »
Sounds like, all you'd need is a match and an oxygen mask, and you could be the first SOHC4 in space.  ;D
Offline speedy gonzalais
« Reply #3 on: September 06, 2008, 07:44:25 AM »
you get less miles to the gallon on gas/propane
82' C90
87' yamaha T80
79' CB125T/CD200 project
82' CB650z
80s kawasaki ae50/150cc project
92' Suzuki GSXR600
80' CB250N
Offline MJL
« Reply #4 on: September 06, 2008, 08:17:08 AM »
On a stock motor, probably. Propane has a little less energy in it, but the octane rating is higher. So, you could build a propane specific motor with high compression to take advantage of the octane, and make more power on propane than on gas.
If I was to do this, I'd make a stock motor run on 'pane just to make sure it could be done, then build a high compression 836 to put it on.
Offline 333
  • Time for change
« Reply #5 on: September 06, 2008, 08:34:07 AM »
Probably hard to find, but 10 Lb bottles would be easier to mount on the bike.  The same height as a 20 Lb'er, but half the diameter.  I had one, but it expired.  And a conversion to a single carb would make this idea more workable.  This was posted in another thread, and is an idea worth some thought.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline MJL
« Reply #6 on: September 06, 2008, 10:26:51 AM »
:Borat: Very nice! :/Borat:
I contemplated a single carb with a manifold made from copper fittings.  I'm just not sure that the right angles would work well, but it'd be cheap enough to try.
Do you remember what thread that pic is from? I like to read it and see how well it ran.
Offline 333
  • Time for change
« Reply #7 on: September 06, 2008, 01:01:57 PM »
No mention of how it ran- just some pics of a weird trike:
http://forums.sohc4.net/index.php?topic=39958.0
