Author Topic: F3 motor teardown (lots of PICS) is it good?  (Read 2066 times)
Offline Flying J
« on: September 11, 2008, 09:06:02 PM »
This is my spare motor that i just bought. Thought id use the best of both motors and practice pulling it apart. Here are some pics. How do the valves look. The tops were not mushroomed but the tappet screws were looking a little worn. this is my firs teardown so any input on what I'm looking at here, good or bad, let me know.
Are any of these valves reuseable
What are those lines are they bad?
The worst looking piston in the bunch
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
Re: F3 motor teardown (lots of PICS) is it good?
« Reply #1 on: September 11, 2008, 09:21:23 PM »
Good work ffjmoore  :)
Valves look normal, but it's hard to tell while they're in the head. The need to be taken out and checked to see if they are bent/worn/burnt.
The 'worst' piston looks like it has some foreign object damage on the dome......likely piston ring bits. Are the rings complete on that one?
The one with the lines looks like it has rubbed the case in the process of disasembly.....not like battle damage? I've not seen lines like that before, they look to organized to be seizure damage but it could be.
 Matt.
Gallery at:
Offline Flying J
« Reply #2 on: September 11, 2008, 10:08:25 PM »
All of the rings are there. I wipped it with a towel and most of it came off, the rest feels like it will come off with a wire brush. The lines arent as bad as they look in the picture and judgeing by the fact that they were covered in the blowby staining in them say they have been there for awhile and not getting worse. Ill try to pull the valves tomorrow.
« Reply #3 on: September 11, 2008, 10:27:33 PM »
check how much play valve stem to guide
Offline KB02
« Reply #4 on: September 12, 2008, 04:50:19 AM »
That almost looks like the piston had been help by some kind of wrench. How does that cylinder look? Any score marks?
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline Flying J
« Reply #5 on: September 12, 2008, 09:38:18 AM »
cylinders are smooth. no lines. Thats why i think it happend before the motor went together.
Offline Flying J
« Reply #6 on: September 12, 2008, 02:08:32 PM »
Got the valves out. How do you measure the slop in the guides? I wiggled them and the moved very little at all. They all measure .258-.259 in. Spec is .2579 and .2567.
pistons
Intake
Exhaust
Are these useable or are they burnt?
The one still has the valve guide on it. Is that the stock kind?
« Reply #7 on: September 12, 2008, 02:23:26 PM »
Hmmmmmm...the guide came out after you removed the valve. Not good. Also I think those marks on the piston skirt were caused by a ring compressor (a waffle band type)
« Last Edit: September 12, 2008, 02:26:12 PM by MRieck »
Offline Flying J
« Reply #8 on: September 12, 2008, 03:03:28 PM »
I had 1 intake and 1 exhaust guide slide out.
Offline Artfrombama
  • Card-carrying, board certified
  • CB750 K2
« Reply #9 on: September 12, 2008, 03:52:43 PM »
Marks look aligned with the oil ring expander.?.?
Halfassed machinist
Tinkerer/goof-off/Mr. Fix-it
CB750-2011594 Sunrise Flake Orange
CB750E2441103
« Reply #10 on: September 12, 2008, 05:35:40 PM »
Yeah...a good point. Butt points off but that will usually cut into the wall. Interesting. 2 guides sliding out is even  more interesting. ::)
Offline Flying J
« Reply #11 on: September 12, 2008, 11:15:08 PM »
just to clarify. the valve guide didn't slide out still attached to the valve. When i was wiggling the valves out it just came loose and i pulled it up as i was pulling the valve down.
I didn't think they should come out that easy.
Offline KB02
« Reply #12 on: September 13, 2008, 05:26:09 AM »
Maybe its just the angle of the picture, but does it look like there are two different kinds of valves? The outside set looks to have an indent in the center while the inside set look flat across. It could just be the lighting, too, but it caught my eye.
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
« Reply #13 on: September 13, 2008, 05:40:07 AM »
Right....there is no other way the guide could come out. The guide shouldn't come out of the bore....that's the problem.
« Reply #14 on: September 13, 2008, 05:57:32 AM »
Only suggestion i got is send the head to mike and get it fettled properly worth every $ and you KNOW it will be perfect
