Boy, that one's a mess!
Any harness will work on any 750, with the caveats below:
1. The K2-and-earlier harness type has a round ignition key plug. This can be changed, if necessary, like I just did on the HS#1 bike: go to Vintageconnections.com to buy the connector parts.
2. The K3-later bikes had a "safety relay" with a red connector added into the system. This was activated at first by the clutch lever's switch (no starter unless clutch pulled in) and later also by a sidestand switch. Both may be bypassed, if the rider's IQ is more than one digit (this was forced on Honda by Ralph Nader's finegeling with the DOT), and the safety relay can be bypassed as well. If you have this one, PM me at home and I'll try to get some pix together for you, as I'm doing that now to the HS#1 bike, also.
3. Starting at late K3, more than one fuse was used in the fusebox. All models may be converted back to one fuse by joining the two leads at the fusebox, if desired. Earlier harnesses lacked the extra wire of the multi-fuse harness.
