Author Topic: 1975 Honda CB125s - carburetor problem  (Read 1343 times)
chriscraft42
« on: September 18, 2008, 10:37:01 AM »
I am having a problem with my CB125s when I come to a full stop. The carburetor seems to run out of fuel and the bike stalls. When the bike is moving it works just fine. I adjusted the throttle screw and air screw as instructed in the manual. Would anyone have any ireas of what the problem could be? Thanks
« Last Edit: September 18, 2008, 11:58:01 AM by chriscraft42 »
Offline Jay B
Re: 1975 Honda CB125s - carburetor problem
« Reply #1 on: September 18, 2008, 10:45:49 AM »
The low speed jet is probably plugged.
Jay
'77 CB550K
'74 CB350F cafe
2001 Road King
'73 CB175
Offline ken736cc
  • When the cops pull me over, I usually let them off with just a warning.
« Reply #2 on: September 18, 2008, 11:43:21 AM »
If you are certain the carb is clean and adjusted properly, then check your valve adjustment.
Tight valves can cause poor idle and hard starting.
K0 sandcast(in process of restoration), K0 diecast, K0 cafe racer
BMW R69S daily rider, 71SL350, 71 SL100, 63 SS50
